Hawk brakes
Old Apr 18, 2009 | 07:20 PM
pTr73's Avatar
pTr73
Default Hawk brakes
Getting sick of the dust from my GM brake pads... I have the chrome gumbies and they shine like the sun when I finish cleaning them. I take the car out for a 3 - 4 mile drive tops come home and there is a small layer of black dust on them already. It really makes me not want to drive the car after cleaning it. Plus I am getting a few brake squeals here and there and it is a little embarrassing, its americas greatest sports car and the brakes squeal like a 12k hyundai accent?
A friend of mine told me to replace the pads now (dont wait for the factory pads to wear out). It makes sense but my question is has anyone changed over to hawk ceramic? or should I buy the GM ceramic instead. I planned on changing the pads myself.
Thinking of getting these... HAWK performace brake pad R/F combo!
Any input would be appreciated, thanks in advance!
Old Apr 18, 2009 | 07:25 PM
saplumr's Avatar
saplumr
Why not get the GM ceramics? I've got Z06 Hawks and they are starting to squeal.
Old Apr 18, 2009 | 07:28 PM
pTr73's Avatar
pTr73
I thought the hawks would be better than the GM... Do you have any dust problems with the ceramic? I expect some dust but it certainly has to be better than the factory pads now.
Old Apr 18, 2009 | 07:35 PM
saplumr's Avatar
saplumr
Practically no dust compared to stock pads. If I change them I'll probably go with Carbotech pads.
Old Apr 18, 2009 | 08:47 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
I can get you a decent price on Hawk Ceramics, but you are better off going with the AC Delco pads from Gene Culley. Much less expensive and even less dust than the hawks, which have little already.
You wouldn't be disappointed with the hawks, but my experience is the Delcos are better and cheaper.
Old Apr 19, 2009 | 06:15 AM
blueyeszr1's Avatar
blueyeszr1
Account suspended by request 6 Oct 2017
Default Brake Pads
I run the AC Delco ceramics pads with chrome wheels and I am very happy with them. Very little brake dust and good preformance.
Old Apr 19, 2009 | 08:24 AM
mikefili's Avatar
mikefili
I put Hawk HP Plus pads in my C6, they stop good, but the squeal is something that is only heard on a subway train, I bed them and it gets much better, only there just before the car comes to a stop, then after 50 miles of so it comes back, squeal is there from the moment you step of the brakes right thru stop, I am sure that it will get much better if I do a full bed, also a lot of dust, I guess I have to take them out, now what to use? Stock pads fade too quick and seemed unuseable on the track, bu the way , the hawks squealed on the track very bad until they got very hot.
timd38's Avatar
timd38
I don't have a Z06, nut those are what I bought and am very happy. No dust.
Old Apr 19, 2009 | 09:30 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Carbotech™ Bobcat 1521™
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
http://www.ctbrakes.com/
Old Apr 19, 2009 | 11:18 AM
RadarP3C's Avatar
RadarP3C
I have the Hawks and I'm very satisfied with them after 18K miles so far. I have not noticed any difference in stopping performance vs. OEM (Z51). No squeal before the Hawks or after. The brake dust has been reduced about 95%.
Old Apr 19, 2009 | 08:36 PM
CMY SIX's Avatar
CMY SIX
if your brakes squeel, it is because they were not installed properly PERIOD!!!!
Old Apr 19, 2009 | 09:18 PM
pTr73's Avatar
pTr73
I think I might goto Gene Culley and get the AC Delcos. My next question is...
I have 4300 miles on the car, I hardly did any hard braking, except a few here and there to avoid hitting a few idiots. Do I have to cut the rotors? Or can I successfully swap the factories with the ceramics and just bed the brakes?
Thanks to all for any info, previous or in the future...
Old Apr 19, 2009 | 10:28 PM
0corvette pilot
Former Vendor
just bed the new ones in and you will be fine.
Old Apr 19, 2009 | 11:38 PM
FireFalcon's Avatar
FireFalcon
This is very wrong, please don't pread mis-information. There is a known issue of brake squeel from early C6s. You can't avoid the causes of brake squeeling, you can only try to minimize them by reducing the vibration or shifting its frequency.
---Matthew Hicks
Old Apr 22, 2009 | 09:37 PM
mikefili's Avatar
mikefili
Well, I had to take the Hawk HP Plus out, squeal was unreal, I put the stock back in, silent again, I guess I will keep the Hawks for the track, if at all. I maybe get G.M. ceramics for street????
Old Apr 22, 2009 | 10:33 PM
stroked250's Avatar
stroked250
Are there ceramic GM AC Delco padlets for Z06 brakes? ..cost?
Old Apr 22, 2009 | 11:00 PM
jschindler's Avatar
jschindler
I have Hawk Ceramics on my Z06. There is still a little dust - more than other Ceramics I've had on other cars. But it is still reduced by probably 90% over stock.
The nice thing about the Hawk Ceramics is that I don't feel any difference at all. After I got them bedded in, I did six hard stops from 60mph to over 100 within about one minute and felt no fade at all.
So far I have no squeal, but I admit that the other day for the first time I thought I might be hearing a very faint squeal, but I'm not sure - it was extremely faint and there was other traffic around me.
BTW, I've had them on for about 3,000 miles now.
Old Apr 23, 2009 | 10:09 AM
saplumr's Avatar
saplumr
No.
Old Apr 27, 2009 | 08:25 PM
coastalcarolina's Avatar
coastalcarolina
From: Myrtle Beach & Greenville, SC -- Hung Like a Republican -- Network Admin/IT
How are the Hawk Ceramics and Hawk HPS (street) in the rain?
I have heard numerous complaints regarding severe loss in stopping distance...
To Hawk brakes
