rocker panel remove and replace
Old Apr 19, 2009 | 09:41 PM
Red86Cfour's Avatar
Red86Cfour
Default rocker panel remove and replace
I managed to rash into the fiberglass the rocker panel below the drivers side door. How hard is it to remove and replace the panel, and what do salvage pieces usually cost? I'll be looking for victory red.
Old Apr 19, 2009 | 09:51 PM
davidfarmer's Avatar
davidfarmer
it's glued to the underside of the frame, which is a pain, but otherwise not difficult. Since removal usually ends up damageing the rocker (glue is really tough), finding a used one may be difficult.
Unless yours is completely destroyed, any decent body shop should be able to fill and repaint it.
Old Apr 19, 2009 | 09:57 PM
Palli's Avatar
Palli
The toughest part of the job is getting the old one off. The factory glue is a space age epoxy that costs $140 for a twin tube (small) that requires a special gun to dispense. You can use two screwdrivers to push it out and mix it up by hand. Putting the new one on is not difficult and the door can stay on but make sure you got the panel where you want it BEFORE you let it sit overnight. And don't let the cat near your clamps (experience).
Old Apr 19, 2009 | 11:31 PM
danl72's Avatar
danl72
Old Apr 20, 2009 | 12:40 AM
Sparo2's Avatar
Sparo2
I see rockers on ebay all the time. Might want to check it out. They even come painted in all kinds of colors.
Old Aug 25, 2009 | 07:28 PM
jodyeastman's Avatar
jodyeastman
I too am looking for one. I just checked e-bay and found nothing. Maybe you are searching for something that's no longer there.
Old Aug 25, 2009 | 10:47 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
I have a pair available. They are in great condition but would need to be painted to match.
Make offer.
__________________
GO GATORS!!!
2008 Vert
Owned since new in 2007
www.c6c7vette.com
Old Aug 27, 2009 | 12:53 PM
lgm118icbm's Avatar
lgm118icbm
I had some scrapes on rocker not too long ago. They just filled the scrapes and painted the rocker on the car. Only cost like 300 bucks.
To rocker panel remove and replace
