My car 08, A6, F55, NPP, perf. axle, K&N CAI, Vette air,T stat,& tune
11-1-08 1.94 60ft 7.89 1/8th 93.00mph 1/4 mile 12.07 118.18mph.
added Z06 cats & manifolds this spring. Track times this year
4-11-09 1.89 60ft 7.72 1/8th 94.78mph 1/4 mile 11.83 119.97mph
So close to the 120mph. Car weight 3496 lbs with me on board, 1/2
tank of last years gas. So looks like the Z06 stuff helps alot.
Did you re-tune after the Z06 exhaust? What was the DA in November and with this run? Fixing to have the same mods myself on my A6, 2.73. I have the Z06 manifold and cats ready to go on.
Great times! Hope I can do as well.
No retune yet, hope to get a COW tune next month.
Dont know the DA, but the temp. was in the low 50s.
I cut the Z06 H pipe behind the balance tube & use
2&half to 3 in reducers & the rear half of the stock
mid pipe, came out real nice.
Something like this. I also ground the 2 1/2" factory pipes so that I have a tapered entry where the flow enters. If you leave it sharp as in just cutting the tubes flow will be restricted with sharp edges.
