LS2 Cam only guys come in
Old Apr 29, 2009 | 12:09 AM
AlexVette505's Avatar
AlexVette505
Default LS2 Cam only guys come in
I just got a 05 Z51 M6..I have a Corsa Sport catback and a honker intake on the car. I wanna do lg longtubes with a cam soon. Let me know what cam you run and all other bolt ons you have. Also post dyno numbers and 1/4 mile times. I ran a search but im getting mostly ls3 cam cars. cammed ls2 guys putting down around 410-440 and traping around 118-122 sound about right?
Old Apr 29, 2009 | 04:44 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Yep. See sig.
Old Apr 29, 2009 | 10:22 AM
Donuts's Avatar
Donuts
07 Z51 mn6. Breathless CAI, Dynatech headers/cats, Borla Stingers, 160 stat, 232/240 .600 110lsa, put me at 440rwhp and 420tq. I have a Spinfast 92 sitting in the garage that I will put on here soon and that should put me over the 450rwhp mark fairly easily. Ported TB is next.. and if all that doesn't make me happy then a nice set of Trick Flows will be next and I should be right at 500 rwhp .. and roughly for the cost of an installed/tuned Maggie...
If I knew then what I know now I would've saved my money and gone the S/C route.
Old Apr 29, 2009 | 10:45 AM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
I have a customer with an 05 with my RPM-2 cam, RPM ported fast 90,36# injectors Kooks long tubes and a corsa catback and it makes 455rwhp.
I would suggest a set of American Racing Headers if you are goin to get a set. PM me if interested.
Old Apr 29, 2009 | 11:47 AM
chsmith112's Avatar
chsmith112
Yeah but you would also have to spend about 1500 to 2000 for a new hood. Plus you wouldn't have that awesome cam sound.
Old Apr 29, 2009 | 12:23 PM
bunk22's Avatar
bunk22
My mods are Vararam, non-ported FAST, u/d pulley, Comp Cams 230/236 .608/.613 113lsa on XFI lobes, Kooks 1 3/4" headers, x-pipe with cats, Corsa Cat-back and tune. IMO, this cam needs gears and a bump in the compression ratio. Soft on torque below 4000rpm. 3.90 gears are going on as soon as I return from Iraq next year.
Old Apr 29, 2009 | 12:36 PM
Wass's Avatar
Wass
St. Jude Donor '09-'11
With a cam, headers, CAI, u.d. pulley, ported t.b., NPP exhaust I have 438 hp/398tq through 4.10 gears. Add 10-12 hp/tq for same setup through 3.42 gears.
Old Apr 29, 2009 | 02:00 PM
Donuts's Avatar
Donuts
very true, i do love that awesome cam sound...
Old Apr 29, 2009 | 05:00 PM
c6speedjon's Avatar
c6speedjon
http://forums.corvetteforum.com/c6-t...at-mods-4.html
VIDEO
http://www.youtube.com/watch?v=pTvCr....php?f=8&t=671
Since adding the Comp Cams reverse split cam and most recently from a ported oem to a ported FAST 90/90 (retuned) and a Textralia OZ-700 single disk clutch here are the numbers to add to the internal mods list as i am already on the bolt-on list with my 11.98 @ 116.44 - C6speedjon - 07 Z51 M6 -CAI, CB, hdrs, ported int/tb, tune DR - (1970) ....
The cam is a Comp Cams reverse split style 228/222 588/581 114.5
So its a;
07 Z51 M6 - Comp Cam, Vararam, Corsa sport Cat Back, LG motorsport headers, Ls2 port works ported FAST90/90 and Ls2 ported throttle body, Straightline tune, on mickey thompson 275/40/17 DR
These numbers are from Straightline Performance's Mustang dyno;
415 RWHP
391.7 RWTQ
On M/T 17 inch DR's
3210 raceweight (3410 w/me in it)
This was at Byron Dragway in Byron, IL Nov. 1, 2008
60' 1.632
330 4.757
1/8 7.314
MPH 96.96
1000 9.508
1/4 11.354
MPH 121.70
Old Apr 29, 2009 | 05:50 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
2006 C6 A6
466 rwhp and 411rwfts
Cartek 3X Cam
Ported Fast90
Kooks headers 1 3/4, 3' x-pipe, highflow cats
Vararam
Ported throttle body
B&B Rt.66 catback
160 t-stat
Vigilanti 3600 stall converter
Ewp
Asp 10% pulley
60ft.......1.538
330ft.....4.473
1/8........6.929@99.57mph
1000ft....9.053
1/4........10.844@125.83mph
Video of the pass http://s261.photobucket.com/albums/i...onverted-1.flv
Dyno sheet
Old Apr 29, 2009 | 06:05 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
Tony,
any bump in compression?
Old Apr 29, 2009 | 06:08 PM
c6speedjon's Avatar
c6speedjon
I love that vid!!! wow! if only i would of got an auto!!!!
Old Apr 29, 2009 | 06:39 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Originally Posted by carlrx7
Tony,
No. The heads are completely stock, untouched.
Thanks!
Old Apr 30, 2009 | 07:54 AM
Wass's Avatar
Wass
Tony, that's fantastic with stock gears too! What does your "Ewp" mod stand for?
Old Apr 30, 2009 | 12:20 PM
AlexVette505
Electric Water Pump
Old Apr 30, 2009 | 12:21 PM
AlexVette505
What headers and cam you running?
Old Apr 30, 2009 | 02:32 PM
Wass's Avatar
Wass
EWP...Never would have guessed, thanks!
American Racing headers 1 3/4" stainless, high flow cats, X-pipe, Npp exhaust. ECS custom roller cam (Duration = 220s / Lift = 580s). The cam was my most recent installation (ECS cam kit). Stock heads and intake manifold.
To LS2 Cam only guys come in
Old Apr 30, 2009 | 08:25 PM
BartonekDragRacing's Avatar
BartonekDragRacing
446 rwhp/401rwtq. see sig.
Old Apr 30, 2009 | 10:37 PM
AlexVette505
Nice car man..I saw your youtube video a few weeks ago. I really dont want a big cam since it is my daily driver. Your car sounds mean tho
Old May 2, 2009 | 09:10 AM
Nightstalker Medic's Avatar
Nightstalker Medic
444 rwhp/404rwtq. See Sig for mods.
The next mod when i return from this deployment will be a set of a nice set of Trick Flow 225s and a re-tune I should be right around 500 rwhp.
