C6 brake line change
Old Apr 29, 2009 | 07:29 PM
tmak26b's Avatar
tmak26b
Default C6 brake line change
Looking to change my brake line this weekend. I have a question. I assume there are two copper gaskets on the caliper side end of the hose? What about on the hard line side? Anything I have to watch out for before I change?
Also, anyone have the part # for the copper oring? Thanks
Old Apr 29, 2009 | 08:35 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
I dont have the part number handy, but there are no washers on the hard line side. its the other type of fitting, not a banjo type.
Old Apr 29, 2009 | 09:41 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I've read that the stock hoses are overtorqued from the factory and you may have issues with the threads being stripped on the hardlines when you pull the old hoses off. You might want to order the GM fittings in case you need to cut the hardlines and put on the new end fitting. Here's a thread with good info.
http://forums.corvetteforum.com/c6-t...on-for-c6.html
San
To C6 brake line change
