Heat shield rattle ?
Old Apr 30, 2009 | 05:13 PM
vettephyxer's Avatar
vettephyxer
Default Heat shield rattle ?
Has anyone else had their trans hump heat shield start to vibrate and rattle. Mine started doing this about a week or so ago on start up then after things warmed up it quieted down. Now it does it almost constantly. The dealer is replacing it under warranty, I just want to know if this is something I'm going to see again.
Old May 2, 2009 | 01:17 AM
knkali's Avatar
knkali
how did you discover it was the heat shield?
Old May 2, 2009 | 05:32 AM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
Default Cat Conv?
I remember cat conv making a similar noise from some cars years ago.
Old May 2, 2009 | 08:05 AM
Joe Lynch's Avatar
Joe Lynch
St. Jude Donor '09-'11
Anyone have a picture? I have a noise in an '06 that I can't find, maybe I'm not looking at the right area. It isn't the support springs or the pipes.
Old May 2, 2009 | 09:34 AM
vettephyxer
The problem was confirmed at the dealership with the car up on a lift. By the way, the car is an 07 with just 8,000 miles on it.
Old May 2, 2009 | 09:44 AM
knkali's Avatar
knkali
I was up till 2 am driving around trying to find the parameters to make a vibration/rattle to reoccur. It is so sporadic, I doubt I will nor anyone else will be able to find it to fix it. But it is there.
Old May 2, 2009 | 10:29 PM
vettephyxer
With the car up on a lift , someone in the car reving the engine and a good mechanic underneath , it will be found. As the vibration starts he can push on different areas of the shield and the vibration/rattle can be isolated. There's a good chance alot of people are thinking this sound is caused by low octaine/ pre ignition. With my car it started out very subtle but progressed rapidly.
Old May 2, 2009 | 10:40 PM
turbo24's Avatar
turbo24
I have 08 coupe A6 with LG longtubes having the same issue, need to get on a hoist
to heck it out.
Old May 2, 2009 | 10:46 PM
BornSUPERCHARGED's Avatar
BornSUPERCHARGED
I got Elite Engineering's "Abs-of-steel" with "Thermal-abs" heat shielding:
http://www.southerncarparts.com/corv...eel-p-243.html
Other benefits include:
● Rigidly ties the right and left inner chassis rails together
● A must for Coupes and Convertibles!
● Direct, bolt-on replacement
● Greater sense of control behind the wheel when cornering
● Reduced squeaks, creaks and noises while driving
● Significantly decreases the heat transferred to the interior console
● Sound deadening qualities
It's twice the thickness of the stock plate, and doesn't have the sound issues.
Old May 3, 2009 | 06:59 PM
saplumr's Avatar
saplumr
I had an intermittent rattle in the center of the car that drove me crazy trying to track it down. Found one of my x-pipe center support springs loose.
Old May 3, 2009 | 07:49 PM
knkali's Avatar
knkali
Think we found mine. the rt muffler seems to barely be hitting intermittently on something
To Heat shield rattle ?
