"Another" brake bleeding question (!)
Old May 3, 2009 | 02:02 PM
RFP's Avatar
RFP
St. Jude Donor '09
Default "Another" brake bleeding question (!)
As I write this, Mike Golding (a.k.a. Corvette Pilot on the forum, www.thepowdercoater.com on the web), is packing for shipment to me my newly-powder coated calipers.
When they arrive, I will do the caliper installation as well as replace the OEM brake lines with braided stainless steel lines from Doug Rippie Motorsports.
So, here's my question (finally!):
I would much prefer to lift only one end of the car at a time. So, can I do the caliper/brake line install on one end of the car and bleed that end while it's off the ground with the wheels off, and then move to the other end?
Thanks,
Rob
Old May 3, 2009 | 02:39 PM
BEZ06's Avatar
BEZ06
Originally Posted by RFP
......I would much prefer to lift only one end of the car at a time. So, can I do the caliper/brake line install on one end of the car and bleed that end while it's off the ground with the wheels off, and then move to the other end......[/SIZE][/FONT]
Go ahead and do it that way.
I usually have the entire car up with all 4 wheels off, but I usually just bleed the RR, LR, RF, LF.
I know what you're concerned about - the Service Manual says to do the RR, LF, then the LR, RF. I think that's more important if you're using a Tech 2 during the process to open ABS valves and bleed that part of the system.
Take a look at your master cylinder and you'll see a baffle in the middle - that's what separates the fluid so it either goes into the RR-LF circuit or the LR-RF circuit. There are 2 circuits for safety - if a line breaks or you otherwise lose pressure in the LR-RF circuit, the other one should still work so you can stop the car safely with the brakes on the RR-LF.
They are two separate circuits, so I can't see how they know what sequence you're bleeding them in.
So.....I would say that you can safely raise the car and do the rears and put the wheels back on, then raise the front and do the fronts.
Good luck!!!
Bob
Old May 3, 2009 | 02:43 PM
calemasters's Avatar
calemasters
The correct sequence for manual bleeding is:
  1. Right Rear
  2. Left Front
  3. Left Rear
  4. Right Front
Old May 3, 2009 | 03:53 PM
07MontRedcp's Avatar
07MontRedcp
Just make sure you don't get some of the calipers mounted upside down as has happened to some forum members.
BJK
Old May 3, 2009 | 08:58 PM
pistolpete817's Avatar
pistolpete817
Default Stainless Steel Brake Lines
I replaced my C5 OEM brake lines with stainless steel. I had never had any traction control codes before. After the brake line change I had random wheel sensor codes frequently. They were all historical by the time I made it to the dealer. I caught one active and he replaced a sensor after a lot of hassle. I can't say for sure that the brake line change caused the codes but it was a real coincidence.
Old May 3, 2009 | 09:18 PM
CMY SIX's Avatar
CMY SIX
  1. Right Rear
  2. Left Front
  3. Left Rear
  4. Right Front
Old May 3, 2009 | 10:14 PM
RFP's Avatar
RFP
St. Jude Donor '09
Yikes, Mike... that's scary!
As you suggest, I am finding it hard to believe that there is a correlation between the failed sensor and the ss brake lines… but it is another thing to “think about!” Thanks for the heads up.
Rob
Old May 3, 2009 | 10:17 PM
RFP's Avatar
RFP
St. Jude Donor '09
Thanks, guys... I am aware of the "school rule" regarding the 'proper sequence.' I am really asking about possible downside effects of doing it 'a bit' differently.
  1. Right Rear
  2. Left Front
  3. Left Rear
  4. Right Front
Old May 4, 2009 | 06:21 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
Like BEZ said, You won't have any problems bleeding right rear, left rear, right front, left front. I do it all the time.
And,
My wife was able to resupply our shipping supplies while I was in training today and get yours, plus the other 7 sets I did this weekend all out today!
Old May 4, 2009 | 07:17 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
And,
Does that include my wheels??
Old May 5, 2009 | 05:50 AM
0corvette pilot
Former Vendor
yes, plus your wheels, Gene Culley's supercharger, a G37 frame brace and a few other parts. It was a busy weekend!!!!!!
Old May 5, 2009 | 08:55 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
with all that happening, how do you have time to work?
To "Another" brake bleeding question (!)
