Need Help: NPP Exhaust
Old May 3, 2009 | 09:34 PM
430Vett's Avatar
430Vett
Default Need Help: NPP Exhaust
If the NPP exhaust Was taken off of a base model,2008 C6 manual transmission vette, will this fit my 2008 C6 Automatic with Paddle Shift
I need a little help with this
Old May 3, 2009 | 10:25 PM
Dave O's Avatar
Dave O
Yes, it will fit. There is not a manual and auto version of NPP. One size fits all.
Old May 3, 2009 | 10:32 PM
Dave O's Avatar
Dave O
I should have noted, if you were not aware, if you car did not originally come with NPP you will need a controller such as Ed's from Nakidparts.com. For more info, see my install thread on my 06 A6 here.
http://forums.corvetteforum.com/c6-c...ipedreams.html
Old May 4, 2009 | 03:38 AM
SunsetOrangeCreations's Avatar
From: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
As noted the Automatic and Manual trans cars with NPP bi-mode exhaust use the same mufflers.
I make the Exhaust Commander All-in-1 NPP retrofit kit and I am local in the SF Bay Area and can come out and help you install your mufflers and Exhaust Commander system if you would like.
I have tons of controller options for NPP bi-mode exhaust such as Dash DIC reset button control and user selectable rpm opening too, so be sure to do your research.
Click here ---> Exhaust Commander All-in-1 NPP bi-mode retrofit kit.
Check out www.sunsetorangecreations.com for all my controller products.
Ben
Old May 4, 2009 | 07:43 AM
SonOfDreams's Avatar
0SonOfDreams
Former Vendor
St. Jude Donor '09
To Need Help: NPP Exhaust
