alignment experts - ??? - increased neg camber
Negative camber tips the top of the wheel toward the engine
Negative camber can cause wear on the inside tire tread to a point that the inside can be showing belts and the middle and outside edge show good tread.
If you need handling for turns (competition) then you should have negative camber, even up to > -2.0
If you want the longest tire tread life, reduce the camber. I run -0.1 and I'm going today to check it and if possible I'll drop to -0.05. I want maximum tire wear. I do not X-cross.
Rear camber on my car is -0.1.
My car has no "bad" handling traits and cruises quite nicely on the street and highway (usually at 85 but keep that a secret).
Elmer
P.S. I'm not an alignment expert but this information will lengthen the life of your tires.
Butt.....here's some reading material:
http://www.tirerack.com/tires/tirete...nd_Feeding.pdf
It says in that link above:
When it comes to setting the camber, you cannot precisely say in advance what the ideal setup will be. The only way to determine this is to run the car, then measure tire temperatures and pressures.
https://www.hoosiertire.com/rrtire.htm
Scroll down to "Chasis Setup Recommendations" and you'll see where they're talking about -3 degrees of camber for their race tires.
Another thing to consider is the "toe" settings (how the front of the tires point "in" towards each other, or "out" away from each other). Typically you'll probably shoot for zero toe for the street, but for the track you might like a little toe-out for the front tires for a better turn-in when initiating the turn, and maybe a little toe-in for the rear tires to aid in getting the power in when accelerating out of the turn.
So.....you're right - for the street you probably want less camber and probably zero toe for better tire wear, but for the track you'll crank in a bunch of negative camber and adjust toe settings for better performance as well as better wear under track conditions.
Take a look at forum member David Farmer's great site for some info on DIY alignments:
http://davidfarmerstuff.com
You can scroll down on his homepage and see links for "alignment guide", "Camber Plates", "Suspension Setup", "Why Toe OUT", and a bunch of other good stuff.
Have fun reading!!!
Bob
You can run more negative camber on the rear because it is not as critical since the tires are not steering.
Some guys think lowering the camber doesnt move the toe because of the bump steer but in real world cases i believe it does (that ca neb argued al night). Either way if you lower your car or lower the camber you need to check and set the toe. regards, paul
