Brake Squeal
Old May 10, 2009 | 07:10 AM
dlive's Avatar
dlive
6th Gear
Default Brake Squeal
My 05 Z51 brakes squeal when first applied, the dealer says this is normal. Is it? Would installing different brake pads fix the problem? I only have 30,000 miles on the car, so I think they are the orginals.
Old May 10, 2009 | 07:25 AM
Wayne88's Avatar
Wayne88
It's normal for Z51 stock pads to squeal. I changed to ceramic pads, and the squeal and dust went away.
Do a search for 'ceramic brake pads'.
Old May 10, 2009 | 05:32 PM
dlive's Avatar
dlive
6th Gear
Thanks for the help, one brand of pads better than another?
Old May 10, 2009 | 06:47 PM
danl72's Avatar
danl72
Old May 10, 2009 | 11:08 PM
MYREDZ51's Avatar
MYREDZ51
I only replaced the fronts with ceramic pads from Autozone for less than $50 and it made a huge difference. Rears are still stock Z51 pads and not a problem, except more brake dust from those.
Old May 11, 2009 | 06:24 AM
madmxnj's Avatar
madmxnj
Also use brake adhesive on the backs of the pads so that they stick to the calipers instead of vibrating between the caliper and the rotor. The high frequency vibration is the squeal. You can get the brake adhesive in any auto parts store.
Old May 11, 2009 | 06:47 AM
mikefili's Avatar
mikefili
Go out and "bed" the stock pads, every so often I have to do this if they start to squeal, just did it thursday night, silent again.
Old May 18, 2009 | 01:59 AM
2005Redvette's Avatar
2005Redvette
2nd Gear
What does bed mean? , i Assume break in hard. But i have the same issue and my dealer replaced my pads Same problem it never helped? It embarasing and becoming annoying someone please help before i go bald at 20.
O yeah my crack head dealership say's it normal for my car to sound like a Pinto W/ 200,000miles. well they really ddin't say that but they said the squeal is normal.
Old May 18, 2009 | 10:02 AM
TXC6Z51's Avatar
TXC6Z51
I have the same problem, so I ordered a set of GM ceramic pads. No more squeal for me after this week.
Old May 18, 2009 | 11:21 AM
AlexVette505's Avatar
AlexVette505
my 05 Z51 does it as well! really annoying..i will get the ceramic ones once the stock ones are done
Old May 18, 2009 | 11:38 AM
nwc6's Avatar
nwc6
How to bed brakes, http://www.zeckhausen.com/bedding_in_brakes.htm
I followed this procedure when the car was new..Less than 50 miles on it. My Z51 brakes have never made a sound.
Old May 18, 2009 | 11:51 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
To Brake Squeal
