2005 LS2 Power Steering Pulley help. . .
Old May 11, 2009 | 10:33 AM
mmaliszewski's Avatar
mmaliszewski
Default 2005 LS2 Power Steering Pulley help. . .
Hello, I have an LS2 out of a 2005 Vette that I am putting into my 65 Vette. I need to remove the power steering pully and replace it with a smaller diameter one. Can anyone provide help with the following:
How is the pully typically removed from the P/S pump? The shaft has a a hex head. . . Is this an actual bolt holding the pulley on, or is it just part of ths shaft itself?
Can anyone recomend a place to purchase a smaller diameter pulley? It does not have to be billet, a GM replacement would be OK.
Thanks in advance for your help,
Matt
Old Dec 31, 2012 | 01:00 PM
kleyba's Avatar
kleyba
1st Gear
Hi Matt;
Did you ever find a smaller pulley is so what did you use?
Thanks!
