Stock Muffler Modification
I set out to gain a little more rumble at idle a louder bark at WOT but have little to no increase in sound at highway cruse with no burble or crackle on deceleration.
I decided to mess around with the stock C6 muffler even though it is different from the Z06 version.
I gained about a 15% increase in idle rumble, about a 25% increase in WOT sound and no drone or crackle and burble.
I have attached a couple of pictures of what I did and yes I realize one patch is larger than the other it was my first one and I needed to open it up to see what I was doing.
In the pic of the open muffler you can see the main feed tube into the muffler, I took a piece of 2 3/4" exhaust tube split it and covered that tube to block the perferations.
I also would recommend you be pretty darn good with a welder the skins on these muffler are thick and have a damn coating on them making it hard to get a nice weld, not so impressed with my bubble gum welds but the skins are pop can thin, when installed because I cut the tops you cannot what so ever see patches from behind or under the car. You have to know where they are and where to look, great if you are selling or returning a leased car.
Mike
Mike
