Cam shaft installation question
Old May 20, 2009 | 04:18 AM
UK COLIN's Avatar
UK COLIN
Default Cam shaft installation question
Does the sump pan need to be taken off , in order to remove oil pump when changing the cam chain.Thanks guys
Old May 20, 2009 | 11:49 AM
CMY SIX's Avatar
CMY SIX
your kidding, your doing this kind of work and you don't have a set of manuals?
Old May 20, 2009 | 12:11 PM
UK COLIN's Avatar
UK COLIN
Waiting for mannauls to come, if i need a sump gasket i can save time by ordering now as i am in the UK
Old May 20, 2009 | 11:47 PM
c6 batmobile's Avatar
c6 batmobile
The sump pan does not have to come off. When you take off the timing cover there will be a metal gasket down there that sticks out. DONT bend it or try to scrap it off. Just leave it alone and reuse that piece. You will need a new timing cover gasket but that bottom part is not part of it.
Old May 21, 2009 | 04:55 AM
UK COLIN's Avatar
UK COLIN
To Cam shaft installation question
