LS2 crank pully - not "if" but "when"
40K miles, I heard the belt squeek and rattle a bit this morning when I fired her up. Sure enough, I could back the bolt out with my fingers. I was able to get it snugged up with a cressent so my entire holiday weekend isnt going to be ruined at the stealership (although I certainly wont be driving it
) I have been keeping an eye on it for a wile, the last check was last weekend and it was fine (my point being that it failed quickly, perhaps because this was the first week I have been running AC in a long time). I have read several posts stating that if you get past the 15 to 20 K marker without a problem then you should be fine.....well, here is a post to the contrary. Be safe out there guys!
:smas h:
The best cure and future prevention IMO is replace the OEM pulley with an underdrive pulley (such as the SLP PowerBond), also install a crankshaft pin kit (from Magnuson Superchargers or ARP), and use a chromemoly crankshaft balancer bolt from ARP (Summit Racing), so you only have to torque the bolt to about 75 ft-lbs just like the "old days", not the 240 ft-lb 140 degree requirement using the lame-*** OEM stretch bolt! OMG, how stupid is that? Then reprogram your computer to increase the idle up to 700 RPM and you won't have any electrical issues with the alternator. You'll be done happy with an added 10HP, and secure that the pulley will not slip and damage itself and the nose of the crankshaft. This is extremely cheap compared what you could go through if you don't do this.
