Be careful if you use an airgun - the guy that installed my mufflers stripped out the torx end of the endlink bolt and it was b@#ch to get the nut off. Took me longer to get that one nut off than to do the entire rest of the job of replacing the endlinks.
You don't have to mess with the endlink bolts...
Remove the two nuts and two upper bolts and then slide the sway bar left of right and then down out of the way.
Speaking of Torque, my trusty Craftsman Torque wrench **** the bed, so I ended up tighting the whole job down by feel.
Five hours.
Complete Exhaust, Skip shift, Mud Guards and Oil change.
I'm calling it a day, time for a couple of Cold Ones
Half the work was taking my time to lift the car correctly.
Bright and early tomorrow I'll be going for a test drive!
Five hours.
You're 100% right - you don't have to mess with the torx, but when I came out of the waiting area, the kid at the muffler shop already had the complete endlink off. It wasn't until earlier today when I changed out the worn endlinks, I discovered the problem. Enjoy your ride tomorrow, it sounds like you deserve a day off after all the work you did today!
