C6Z06 Catback Removal
Old May 23, 2009 | 08:11 PM
wilson34's Avatar
wilson34
Default C6Z06 Catback Removal
Did you guys have to lower the rear drivetrain in order to remove the catback.
If anyone knows where I can find some info please help.
Thanks!
Old May 23, 2009 | 09:21 PM
cencalc6's Avatar
cencalc6
Thanks!
The only thing that needs to be removed out the way is the rear swaybar
Old May 23, 2009 | 09:36 PM
wilson34's Avatar
wilson34
Did you have the rear of the car in the air?
I'm having trouble because after pulling most out the very end which connects to the H-Pipe begins to hit the the tunnel before getting over the diff.
I can only turn the exhaust so far because the mufflers will hit the ramps.
So all it should take is a lil more manuevering to get it out?
Old May 23, 2009 | 09:42 PM
dkal70's Avatar
dkal70
Thanks!
Heres a link to a bb fusion exhaust install, may give you some information
http://www.youtube.com/watch?v=JxFrS...e=channel_page
If you have a problem opening the link, you can go to Billy boat website
http://www.bbexhaust.com/car/corvette/z06/
and click on the bb exhaust install video.
good luck
It seems you have to lift the vehicle higher to manuever the pipes out the rear of the vehicle.
Old May 23, 2009 | 10:24 PM
dkal70's Avatar
dkal70
Are you planning on keeping your factory muffler setup? What catback system are you installing?
Old May 24, 2009 | 12:43 AM
takeman's Avatar
takeman
St. Jude Donor '10
I had mine up on my raceramps, dropped the sway bar and just had to menuver the muffler either far left or far right depending on the side. No need to drop anything else or cut the pipes.
Old May 24, 2009 | 01:17 AM
wilson34's Avatar
wilson34
Keeping the stock exhaust, as with what catback Im installing.....
The eBay one haha. Got it for cheap and said why not. Gonna see how it goes.
Old May 24, 2009 | 01:25 AM
wilson34's Avatar
wilson34
Thanks guys, I just watched the install video and I tried removing the passenger side first which they say is the hardest and does require some extra wiggle room.
So looks like tomorrow Ill drop the drivers side then slide out the passenger side.
Thanks!
To C6Z06 Catback Removal
