Redline Vs. Amsoil Vs. GM fluids
Old May 24, 2009 | 03:44 AM
LS WON's Avatar
LS WON
Default Redline Vs. Amsoil Vs. GM fluids
On the C-6 Corvette 2005 with A-4 transmission and rear differential which fluid do you prefer to use and why?
Old May 24, 2009 | 08:51 AM
ErnieN85's Avatar
ErnieN85
I'm pretty much sold on Redline. I've used it on the track & street with excellent results for four years now. when i replaced the clutch packs in my differential last fall 100,000 miles on it the gears and bearings were like new!
Old May 24, 2009 | 07:58 PM
LS WON's Avatar
LS WON
I have Redline in my rear diff and can't tell the difference but on the manual trans Redline make the shifting alot easier and smoother. Total day and night difference from factory.
Old May 24, 2009 | 08:03 PM
VET4LES's Avatar
VET4LES
I'm sticking with GM. Everything works fine and I see no reason to change.
Old May 24, 2009 | 08:30 PM
LS WON's Avatar
LS WON
On the C-6 I was lucky and didn't have the rear end chatter like most did.
Old May 24, 2009 | 09:26 PM
VET4LES's Avatar
VET4LES
I did and the dealer changed it with the new fluid. Have had no problems since.
Old May 24, 2009 | 09:45 PM
LS WON's Avatar
LS WON
Hopefully the chatter won't return on this new LS Dexron fluid like it did on the old GM fluid.
Old May 24, 2009 | 09:49 PM
saplumr's Avatar
saplumr
Some swear by the other brands but it seems hard to actually tell any difference between them.
Old May 24, 2009 | 09:57 PM
LS WON's Avatar
LS WON
That would be Amsoil Severe Gear with the slip addictive.
Old May 24, 2009 | 10:08 PM
saplumr's Avatar
saplumr
I've never had the rear chatter but I change the fluid every 2 years anyway with the GM stuff because it sits through the winter and I've been told moisture can develop. If someone could have a scientific study with the available products I would go with the one that comes out on top.
To Redline Vs. Amsoil Vs. GM fluids
