"Aluminum radiators,,"
Old May 24, 2009 | 11:40 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Default "Aluminum radiators,,"
Are they really worth the extra cost?
How do You Guys that have them,like them?
Old May 24, 2009 | 12:10 PM
Bill Suttie's Avatar
Bill Suttie
The core of your factory radiator is aluminum. What more do you need??
Old May 24, 2009 | 12:13 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
I'm not sure how much temp difference you'd see with an aluminum radiator but a larger radiator could prove beneficial. Especially for a boosted engine in the California heat.
Old May 24, 2009 | 01:39 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
You only need a bigger radiator if the stock unit can't keep the coolant in the desired temp range. Here in Texas, the stock radiator with a 160 'stat keeps my coolant temp at 180. I don't run it at the track, which would increase the demand on cooling system.
If yours is not keeping up, I understand there are a number of good aftermarket radiators out there.
Old May 24, 2009 | 02:52 PM
1bdasvt's Avatar
1bdasvt
Thanks Guys!
Old May 24, 2009 | 02:53 PM
1bdasvt's Avatar
1bdasvt
I meant a "larger" aluminum radiator.
Old May 24, 2009 | 03:15 PM
Bill Suttie
Face area is more beneficial than core depth. There is not much room to increase W & H
Old May 24, 2009 | 03:55 PM
1bdasvt's Avatar
1bdasvt
Well then I guess I'll drop the idea!!
Old May 24, 2009 | 06:41 PM
Mez's Avatar
Mez
Do you have an overheating problem? I see you have lots of power which creates a lot of heat. What temp are your running and why do you think you need a bigger radiator.
Old May 24, 2009 | 09:09 PM
danl72's Avatar
danl72
Old May 24, 2009 | 09:16 PM
1bdasvt's Avatar
1bdasvt
Originally Posted by danl72
Dan,,,,,,do You have "any" experiance with this matter??
If You don't ,,,,,,PLEASE,,,,,, ,,,don't post in this section!!!!
Old May 24, 2009 | 09:26 PM
johnodrake's Avatar
johnodrake
Moderator
Bigger radiator will make recovery time quicker. It doesn't really change the run temp.
Old May 24, 2009 | 09:29 PM
1bdasvt's Avatar
1bdasvt
Thanks for the good advice John,,,,at least You don't just post for "points" like some other Guys!!!
Old May 24, 2009 | 09:36 PM
johnodrake's Avatar
johnodrake
Moderator
:o I have been keeping track of temps for a year now since I changed to the DeWitts radiator. It is a good piece and I think it is worth it, but it really hasn't altered my run temps.
You haven't posted your run temps. What are they?
Old May 24, 2009 | 09:41 PM
oneblackvette's Avatar
oneblackvette
Dewitts and yes it makes a world of difference.
Direct Fit radiator features two rows of 1" tubes, which doubles the cooling capacity of a factory single row. Exclusive "press formed" end tanks are hand tig welded by expert craftsman, eliminating the factory plastic tanks. This with the right t-stat and fan program no more heat problems ever.
http://www.dewitts.com/pages/product...asp?ProdID=400
Old May 24, 2009 | 09:54 PM
1bdasvt's Avatar
1bdasvt
John,,the temps haven't been too bad{around 210 at most,,without track running} but just wanted to do it for lower temps if it's not too much$$.
Old May 24, 2009 | 09:55 PM
1bdasvt's Avatar
1bdasvt
Sounds like the one!!
Thanks much!!
To "Aluminum radiators,,"
Old May 25, 2009 | 01:28 AM
v502's Avatar
v502
Dewitts radiator is one i have with 160 T-stat with a Low/High fan switch u never face an overheating issue.
My car is 570rwhp with A&A kit and i do straight runs on weekends from 0-160 on closed road and all back to back with fan on and never get over 200F.
Its really great for traffic if ur car a DD or for cooling purpose on track or preventing it to reach the high levels.
That is just from what i experienced
Old May 25, 2009 | 05:40 AM
Mez's Avatar
Mez
That's about right with the factory thermostat. Do you still have the factory thermostat?
Mine ran 204-210 until I changed to a 160 'stat. Now I run at 180 consistently.
Old May 25, 2009 | 05:51 AM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
Default Dual Fan
I would also add the dual fan kit while your at it. It WILL drop your temps.
