hidden NPP switch.
All you have to do is pull the cig ltr fuse, then undo the console so you have space for your hands to run the wires thru the cig ltr. It has some square cuts. I use two 18 gauge wires, fed them thru and solder them to the switch (from autozone). If you use smaller gauge wire, you might have enough room to run the gnd wire for the little light in the switch. I only had 18 gauge, and with 3, the switch would pop out.
I used some shrinkable sleeves at the switch on each wire for isloation. Did a Gnd test for precaution, ran the wires (per the diy on here -works sweet!-). Of course, do not put the cig ltr fuse back in.
note: I did not remove the cig ltr at all, the switch is of the exact same diamer than the lighter, and it has holding tongs on each side, so just slide it in and pop it in!
ps: this is on an 08, I do not know if prior model years are the same.
