Brake pad silicone
Old May 25, 2009 | 03:08 PM
mikefili's Avatar
mikefili
Default Brake pad silicone
I am going to give the HP Plus pads another try, when I had them in last the amount of squeal was too much to put up with, my question is this,
should I put the grease on the back of the pads and allow it to dry fully, somewhat, or install the pads while the silicone is still wet? Last time I applied it and installed the pads while still wet, what is the correct way to use the silicone grease?
Old May 25, 2009 | 06:57 PM
mikefili's Avatar
mikefili
Any advice????
Old May 25, 2009 | 08:40 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
just put it on the backs and install them. My first set didn't come with grease and were very noisy. The 2nd set came with grease so I used it just because, and they were very quiet on the street (Z06 calipers, but shouldn't matter)
Old May 25, 2009 | 09:20 PM
mikefili's Avatar
mikefili
Thanks for the help, Should I put it on the back of the piston side pad only or back of both pads?
Old May 25, 2009 | 09:23 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
It won't hurt to put it on both sides as it just helps to dampen vibration, which is what sound is.
San
Old May 25, 2009 | 09:47 PM
mikefili's Avatar
mikefili
San
Yes, that does make sense, thank you.
Old May 26, 2009 | 11:14 AM
CMY SIX's Avatar
CMY SIX
on the pins too... and were the pads hang on them, any where there is metal to metal cotact
To Brake pad silicone
