Motor Pre Lube System
Old May 25, 2009 | 10:44 PM
Redrocket1045's Avatar
Redrocket1045
Default Motor Pre Lube System
Do any forum members have this type of set up installed?
If so - where did you mount your accumulator tank and where did you hook up your "hot" solenoid wire. TIA
http://www.motorprelube.com/
Old May 26, 2009 | 07:54 AM
ErnieN85's Avatar
ErnieN85
I haven't seen any of this make in use most use a 3qt accusump from canton racing. usually the tank is mounted in the left fron fender just behind the wheel and plumbed into the oil cooler or the main journal at the front of the block. it's most useful in high G cornering on track.
prelube being a bonus
