A6 Shift Points programmed too high????
Old Jun 9, 2009 | 01:38 PM
efg's Avatar
efg
Default A6 Shift Points programmed too high????
I had my engine and trans HP tuned with a Mail-in tune and got
good results with the engine and TM management from a tuner in
Texas, but I am not sure about the A6 trans tune.
On wide open throttle the shifts are more into the power band,
but the 2nd gr shift point is at [B]7000 rpms (redline is 6500rpm).
I realize that this occurs at less than a seconds time, but will the
shift past Redline hurt the engine?
Old Jun 9, 2009 | 01:42 PM
FloydSummerOf68's Avatar
FloydSummerOf68
I wouldnt shift much past 6500 on the stock valvetrain.
Old Jun 9, 2009 | 02:39 PM
Hot Rod Todd's Avatar
Hot Rod Todd
I have mine set at 6600, absolute rev limit set at 6700. (scans show it shifting at about 6550 actual). It seems to work well and a 200 rpm increase should be safe. 7000 seems too high to me and even with headers may not provide a better time in the quarter mile. I also found that the 2009 timing allows the paddles to be quicker on my 2008. Another thing I did not do that I have seen on some tunes is turn off torque reduction on the shift. Until the new version is released that allows us to reduce but not eliminate reduction on the shift, I'll leave it on.
Old Jun 9, 2009 | 03:10 PM
Ragtop 99's Avatar
Ragtop 99
are you sure if it is really 7k based upon logged data rather than the tach?
Old Jun 9, 2009 | 04:38 PM
efg's Avatar
efg
Good Point. I'll have to find out the actual programmed rpm. I guess
the tach can be innacurate to read on its own.
Old Jun 9, 2009 | 04:45 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Send me your tune and scan and I can take a look for you. If you send me a PM I'll reply with my e-mail address.
Christopher
Old Jun 9, 2009 | 06:25 PM
knkali's Avatar
knkali
The subfloor is on it!
To A6 Shift Points programmed too high????
