LS2 Engine Cutting Out
Old Jun 11, 2009 | 10:26 PM
Will from Alabama's Avatar
Will from Alabama
4th Gear
Default LS2 Engine Cutting Out
When hot the engine cuts out. After 5 or 6 hours on the road car begins have engine surges and coughs. Had scanned this am, mechanic could not find anything wrong. Drove 5 hours did it again. HELP, I am 3 days away from home in Minn. It is at another Chevy dealer. Thanks.
Old Jun 11, 2009 | 10:29 PM
c54u's Avatar
c54u
Are you running on the same tank of gas after 5 or 6 hours? If so, then you may want to have your tank at least a 1/4 full at all times. Maybe something with the fuel delivery system.
Old Jun 11, 2009 | 10:44 PM
danl72's Avatar
danl72
I agree. Sounds like it could be a fuel system problem.
Old Jun 11, 2009 | 10:51 PM
Will from Alabama
4th Gear
full most of time eng.starts losing power and yesterday after all day on road engine coughed a bit and pulled over, towed to chevy codes didn,t tell us anything. Did same thing today after 5 6 hours have it at chevy dealer here in alexandria, mn. Will see what he can find in am.This is a 05 vette 20,000 miles.thanks.
Old Jun 11, 2009 | 10:55 PM
c6 batmobile's Avatar
c6 batmobile
We need some more background on the issue. Like the info surronding the event. Type of driving eng temps amount of fuel in car etc.
Old Jun 11, 2009 | 10:58 PM
Will from Alabama
4th Gear
Old Jun 11, 2009 | 11:09 PM
Will from Alabama
4th Gear
engine temp 195 steady,no info shown on DIC to give a hint.Think may have something to do with throttlebody sensor or mayby oxygen sensor causing computer to try to compensate.
Old Jun 12, 2009 | 12:01 AM
glennhl's Avatar
glennhl
Only time I've had an LS engine cut out is due to either a loose spark plug wire (you really have to push down hard until it clicks) or a dirty MAF. You can clean the MAF with maf cleaner or electrical cleaner.
Old Jun 12, 2009 | 12:36 AM
Paratrooper307's Avatar
Paratrooper307
Might want to look at the fuel pump too. Could be having an issue where its getting too hot and shutting down, or an ignition/coil problem.
Old Jun 12, 2009 | 01:49 AM
c6 batmobile
I would say maf maybe too. I can really cause your car to do weird things. Start there as its an easy fix. I dont think heat is a problem since his temp is only 195 which is actually a little low for prolonged highway driving.
To LS2 Engine Cutting Out
