Anyone know what P0690 root problem would be?
Old Jun 12, 2009 | 04:31 PM
ktoonsez's Avatar
ktoonsez
Default Anyone know what P0690 root problem would be?
Just got into my car for lunch and check engine light comes on with P0690 "ECM/PCM Power Relay Sense Circuit High". I guess it must think the voltage is to high coming into the PCM. Anyone have this or know what the heck could be wrong?
EDIT:
GM's text for this error is "Engine Controls Ignition Relay Feedback Circuit High Voltage ECM"
__________________
Old Jun 12, 2009 | 05:01 PM
99ssconv's Avatar
99ssconv
Powertrain relay either stuck on or shorted to voltage...Swap it and see if the concern goes away...
Old Jun 12, 2009 | 05:07 PM
ktoonsez's Avatar
ktoonsez
I'm guessing your talking about 1 of the big gray relays in fuse block under the hood?
Old Jun 12, 2009 | 05:52 PM
ktoonsez's Avatar
ktoonsez
Another update:
Pulled my jumper (this has been installed for several weeks) out of the "Emmissions EVAP" fuse for running my tranny cooler fan and the problem went away for 3 straight starts. Will keep my eye on it.
To Anyone know what P0690 root problem would be?
