Valve Float or Tuning Issue?
Old Jun 12, 2009 | 05:45 PM
Slwsvt's Avatar
Slwsvt
Default Valve Float or Tuning Issue?
Hello all,
Just got my recently built 404LS2 on the dyno for some tuning. It is a Livernois 404 with 243 heads (330cfm, 240cfm), Pat G spec cam 239/247 .623 114+2 on LSL lobes, ported FAST and supporting mods. She pulls nice and steady and is making 498rpm right about 6200 while still climbing then all of a sudden it hits a wall and nose dives. From 498rwhp at 6200 to about 400rwhp at 6800. Tuner thinks it is valve float. I have Patriot springs in there. With the cam sheet it called for a 7.40 in push rod, but with a 7.35 the geometry was right on. Do you all think it is the valve float due to weak springs?
Old Jun 12, 2009 | 06:15 PM
c6 batmobile's Avatar
c6 batmobile
What are your springs rated to? The make .600 lift and .650 lift springs. If you have .600 lift then yeah its gonna float.
Old Jun 12, 2009 | 06:39 PM
Slwsvt's Avatar
Slwsvt
I don't remember exactly which springs I received. I purchased a cam and spring kit from Advanced Dyno on here when I first did the cam change. Of course I upgraded this cam again.
Old Jun 12, 2009 | 06:57 PM
c6 batmobile
Check your lift on the springs. Also it is always recommended to change springs when you upgrade to a different cam regardless of lift.
Old Jun 13, 2009 | 06:31 AM
SpinMonster's Avatar
SpinMonster
Patriot makes several springs and you should be using the gold extreme duals.
Old Jun 13, 2009 | 07:27 AM
edcmat-l1's Avatar
edcmat-l1
Post a graph.
Old Jun 13, 2009 | 08:06 AM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Patriot Performance Gold .650" Dual Spring Kit Technical Specs:
Install Height: 1.800"
Max. Valve Spring Lift: 0.650"
Spring Pressure Closed: 135 lbs. @ 1.800"
Spring Pressure Open: 375 lbs. @ 1.150"
Coil Bind: 1.090"
Retainer Material: Titanium
Patriot Performance Xtreme .660" Dual Spring Kit Technical Specs:
Max. Valve Spring Lift: 0.660"
Spring Pressure Closed: 155 lbs. @ 1.800"
Spring Pressure Open: 410 lbs. @ 1.140"
Coil Bind: 1.090"
Old Jun 13, 2009 | 03:24 PM
Slwsvt's Avatar
Slwsvt
Originally Posted by edcmat-l1
Post a graph.
I have the graph, but only in the dynojet file format. How is converted over to post?
Old Jun 13, 2009 | 03:25 PM
Slwsvt's Avatar
Slwsvt
Coil Bind: 1.090"
Coil Bind: 1.090"
I am ordering that exact same set on Monday. On another note, what is usually the HP loss with 4.10 gears?
Old Jun 13, 2009 | 04:24 PM
Craigster05
Wait...do you have 4.10s installed? If you do, there is a secondary rev limiter that kicks in 500rpm before the final rev limiter. It's in the "RPM Limit Accel Thresh vs Accel" table using HP Tuners. If you have 4.10s and this wasn't adjusted in your tune, it's more than likely the problem.
Old Jun 13, 2009 | 11:20 PM
Slwsvt's Avatar
Slwsvt
Craigster05, I dealt with that animal when the gears were installed late last year. The weird 2nd gear only rev limiter. This is a totally different animal.
Old Jun 14, 2009 | 12:10 AM
Slwsvt's Avatar
Slwsvt
Here is a dyno sheet.
To Valve Float or Tuning Issue?
