I began to think my installer might be at fault with the gear install, but then I began researching and discovered that many members throughout the country are running into this problem, and their installers have been confiming the story about the Italian gear manufacturer.
I also can't understand why no American firms are making gears. If I owned a factory, I'd be looking to jump all over this opportunity. Go figure.
My installer told me that the 2 sets of 410's I had were made by American Axel and my stock gears were returned in an American Axel box??? The 390's that are in now I have no idea where they came from and am affraid to ask. Spin, do you know where these gears come from?
My first 4.10 ring & pinion install lasted 500 miles. Horrific whine. Needed ear plugs. They were defective and replaced N/C by the installer about 14 months ago. I really like the 4.10 gears, but it's interesting others have had the same problem.
Mine were also replaced n/c but 3 installs tied my car up for 4 months. Drove it a total of 2 1/2 weeks for the whole summer. Needless to say I was not a happy camper.
Are you suggesting that you should do gears while doing the clutch OR if you do gears, get a new clutch? Reason I ask - I am doing 4.10 gears in the next week or two.
Anyone doing a clutch has to have the entire TQ tube/trans/diff removed from the car so the overlap there is a no brainer. The amount of time it takes to bolt on the new diff and fill it with fluid is 15 minutes so the labor would be free on the diff install. With clutch installs running from 600 to 1000 in labor it makes sense to upgrade these two together.
To do the diff alone requires the cradle to be removed and the exhaust dropped.....its 1/3 of the way in.
Yikes...My car was only tied up for a few days. I have about 15,000 miles on my second set of 4.10 gears. I don't track the car, but I do play with it. The gears are holding up fine. There is a slight whine between 60-70 MPH, but most probably wouldn't notice it.
Gee...I hope the QuickSilver Mod God doesn't post in this thread and say "I told you so".
Bob, glad you are happy sir!!! After reading this thread I made a quick call to RPM Transmissions to get the real story on this situation.
RPM Transmission says they use Motive Gear (An Italian made piece). They also said that they have had virtually zero issues with 3:90/4:10 gears. They said they have had some issues with 3:73s, but every one of those were installed in C5s, not C6s.
Spin had an absolutely spot on suggestion above... Get your parts/gears/diff from the same shop doing your install. This takes all of the "finger pointing" out of the equation.
Agree with getting them from the same shop. In my case, my rear end was sent to a different shop, which I was unaware of at time of purchase. My tuner was at the mercy of the other shop who gave them $hitty service, which resulted in my tuner giving me $hitty service. My tuner first did CAI and Corsa Sports, then h/c, LTH, x-pipe and a dyno tune. The third trip was for 410 gears. I've spent about $9000.00 there and due to this poorly handled situation, they probably won't see any more of my money. BTW for what it's worth, my stock gears were returned in an American Axel box, labled diff. case, part # 40007876, made in USA. I searched Am. Axel aftermarket parts, but could not locate the number. Not even sure if it's the correct box.
Ron. I'm also a Bob, think your quote was to another Bob. We all appreciate you chiming in, as you can see, a lot of members are having trouble with these gears sets. Also learned last week, Chubbs77 just got 390's, from the same place I did, and they are whinning at 500 miles?????
I have 10k problem free miles on my motive 3.90's. I thought they may
too low but they are perfect even S/C'd!
I do like the 390 as they took care of the slow startups. Didn't get too many miles on the 410's but the results were similar. I believe the 390's increase the ratio by 15% and the 410's by 20%. Currently have 5000 on the 390's, so far so good.
My second set of 3.73's recently went out. Got just over 600 miles on each set before they started whining real bad. This is in a 2005 c6. Luckily the shop that got the gears did the install and everything in the rear. I am still out of a lot of labor and a lot of $$$$$ in shipping though to get the rear back to them and from them back to me every time. Sucks that I have to pay for them to send it back to me when it is not even my fault though. I am switching to a 3.42 GM gear this time though (a4 trans) so hopefully they won't slow me down too much and won't start whining. I paid to have 3.73's in the car, not 3.42's, but I would rather have them last...
What is the break in process of new gears? I'm suppose to be getting 4.10s installed thursday and i'm getting scared cuz of all the problems people are having.By the way i have an 01z06 and was thinking of maybe just going with 3.90s.Any advise is appreaciated. Thanks
If you track the car 4.10's will cause you to shift into 5th before the end of the quarter mile. Don't have those numbers handy. On the 3.90's, you will be at 140 mph at 7000 rpm in 4th. Ask your installer what their recomended break in procedure is so that there is no misunderstanding between you and them. Good luck. OOPS. See you have an 01 Z06. Don't know about those numbers at all. Being in the c6 section I assumed???????? The breakin procedure use the comment above.
Thanks for the clarification. I thought that was the intended message. I may just have the clutch done now anyways as a preemptive strike. I am also doing the hardened output shaft and a rear brace for good measure. I am looking forward to the changes and some new tires.
Possibly stupid question - how much mph increase in trap speed should I see, if any. I already trap 120 mph with 385 rwhp, runcraps, manual trans and the stock rear 3:42 ratio.
Sorry for the detour and quasi hijack, I am now returning you to your regularly scheduled program..............
