Does the powerbond UD pulley that works on 05-07 C6's work on 08 and up as well? It is listed for all C6's on a vendor site but I was unable to find much info on it when I searched here except for on C5's. I had the powerbond on my LS2 GTO and it made 10rwhp alone so I am wanting to get one on my C6.
Be sure what ever pulley you get that it has molded rubber and not O-rings between the outer ring and inner hub. The O-ring type tend to allow the outer ring to move vs. the inner and over time and will no longer be balanced. Generally you won't see a snap ring for retention with the molded. Also good idea to be sure it's SFI approved.
