I'd like to get one as well, preferably without the speaker hole. Actually, I'd even take a two pod, if it didn't have the speaker hole. I can't even find on of those.
Got it in, haven't really figured out where I want it exactly yet, but this is pretty close. But I have to play around with it a bit before I install the wiring through. But I think you get the idea, should work great.
That's not a speaker it's a mic for the nav and on-star and all you have to do is buy one from GM to fill the hole.
can you remove the suction cup flip around and mount industrial velcro on foot of pod?
No reason I can think of why you couldn't. There is a block that holds the suction cup as well as holding the housing together with two screws. You could attach velcro to that and mount it someplace I suppose. But there are tons of other pods out there with no suction cups.
They sell MAP sensors that connect to the gauge, so yes, this gauge will work as a boost gauge. It actually has two analog inputs, so you can use one for boost and the other for a wideband. That's my intent eventually.
