C6- engine noise when cold
Old Jun 24, 2009 | 08:50 PM
kpm778's Avatar
kpm778
Default C6- engine noise when cold
I'm am new owner of a 2005 corvette with a six speed. When I start the engine and rev it I can hear a noise possible in the valve body. Once the engine is warmed up it goes away. The engine runs fine other than this issue. A corvette owner told me that the engine does make noise until it is warmed. Any advise or is this normal?
Old Jun 24, 2009 | 11:11 PM
jpuli28's Avatar
jpuli28
Is it a clicking or a knocking?
I have an 07 A6 and was told by the Chevy Service Advisor its the fuel injectors. Its "normal".
Old Jun 25, 2009 | 07:50 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
The "sewing machine" noises are typical when the engine is cold.
Old Jun 25, 2009 | 08:32 AM
marc8090's Avatar
marc8090
Sometimes the lifters are noisy until they pump up with oil pressure. It should go away though in a few seconds, it should not take until the engine warms up for the noises to go away. I also would not rev the engine at all until the noises stop.
Old Jun 25, 2009 | 09:33 AM
kpm778's Avatar
kpm778
Its tough to discribe but it is a whoosing type noise when you hit the gas. You can also hear it while going through the gears. It seems to go away after it gets up to normal temp
To C6- engine noise when cold
