C6 Dual Flow / Filter Intake Questions ???
Old Jun 25, 2009 | 12:54 AM
Ed 718's Avatar
Ed 718
Default C6 Dual Flow / Filter Intake Questions ???
I just picked up a used Carbon Fiber Dual Flow intake similar to the one from WCC seen in the link below. The intake looks exactly like the one from WCC but not sure if in fact it is the WCC intake. The carbon fiber duct looks the same as is the tubing also however only the filters are a different color than what's pictured.
The install was fairly easy however the seller did not have any brackets to hold the intake in place which sits the intake loosly one the car. Does anyone have pictures of the intake with the bracket installed? Also on the chrome tubing there is a breather hole of some kind on it plugged with a rubber seal which can be removed. What is this hole for and should it be plugged or open? The instructions from WCC does not mention anything about this hole but then again this may not even be the same...Anyone?
Old Jun 25, 2009 | 11:18 PM
Ed 718's Avatar
Ed 718
Anyone
Old Jun 26, 2009 | 01:27 AM
Former Ricer's Avatar
Former Ricer
Nothing should be unplugged you dont want dirt and other particles making it to your engine. Are the filters blue?
To C6 Dual Flow / Filter Intake Questions ???
