C6 ZO6 Center Console Removal
Old Jun 27, 2009 | 07:00 PM
Hot Marauder's Avatar
Hot Marauder
Cruising
Default C6 ZO6 Center Console Removal
I'm trying to remove the center console on my 2008 ZO6 and cannot figure where to, or how to remove shift ****. Anybody know or have pics even?
anything else i should be aware of? I have everything else loose and unplugged. I'm just stuck on the shifter.
Old Jun 27, 2009 | 08:50 PM
Fast06Z06's Avatar
Fast06Z06
If its for the shifter then you are all set. posted on your other thread. If for the console search and youll find nice instructions but basically two bolts below the emergency brake arm, two bolts on back inside console cover, rest are snapsand gently work out disconnect harnesses.
Old Jun 28, 2009 | 10:05 AM
Hot Marauder
Cruising
i got them. Thanks. I had originally meant to post in general.
thanks again
To C6 ZO6 Center Console Removal
