coolant temp question
Old Jun 29, 2009 | 03:51 PM
BLACKJACK08's Avatar
BLACKJACK08
Default coolant temp question
I have noticed that my engine temp which used to always run at 172 degrees on the parkway is now running at 178-180 degrees. the outside air temp hasn't changed much. I know its not much of a difference but it has changed and I was wondering what it could be. I checked the radiator and it was clear. the antifreeze is up to level. Any suggestions. The car otherwise runs great. It was on the track the other day and went up to 230 degrees but ran great. It could down off the track but ran hot in traffic, up to 212. I dont remember seeing this happen before.
Old Jun 29, 2009 | 04:12 PM
6Speeder's Avatar
6Speeder
Our Corvettes are like vacuum cleaners. Check the front of the radiator for debris.
Old Jun 29, 2009 | 04:27 PM
achilds's Avatar
achilds
Stock 187 degree tstat? or aftermarket 160 tstat? Sounds like it is an aftermarket if you are typically running 178 to 180 on the highway. check your coolant level as well as looking for anything blocking airflow in front of the radiator.
Old Jun 29, 2009 | 06:08 PM
Gofan's Avatar
Gofan
Default at a 100 degrees
In the current heat wave my car has been running north of 190. Running like a top.
Old Jun 29, 2009 | 07:16 PM
VET4LES's Avatar
VET4LES
If your running a stock thermostat 178- 180 is cool. Are you sure that's normal? Polls on this forum have found the upper 190's are normal in normal ambient temperatures and stock thermostat.
Old Jun 29, 2009 | 07:21 PM
BLACKJACK08
sorry for not clearing that up, i am running 160 therm.on a 2008 z51. i have had it tuned, headers, hi flow cats, borla and vararam intake for over a year now. i have looked at the radiator and all looks clear, no visual debris. i will try to blow it out with a compressor though. i have never seen this type of fluctuation and it wont run at 172 like it was. it frequently goes up to 200 now when i come off the parkway. it used to go to 196 the fan would come on and lower it to 192. cant pinpoint why it all of a sudden started running 8 degrees warmer on the parkway. engine is running great otherwise.
Old Jun 29, 2009 | 11:59 PM
achilds's Avatar
achilds
Did you install it yourself? They can leak really slowly if the gasket is not in just right and the temps will go up gradually. Also some of the aftermarket ones can go bad. I know I had one in my 2006 C6 go bad.
Old Jun 30, 2009 | 03:26 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
is it 8 degrees warmer outside?
Old Jun 30, 2009 | 06:25 AM
REVAK's Avatar
REVAK
Manual trans. ? My temps will run higher in 5th or 6th than they will in 4th at 50 to 60 mph .
Old Jun 30, 2009 | 06:41 AM
RareSS9596's Avatar
RareSS9596
You don't want to know what mine is running at. Getting an aftermarket aluminum radiator and maybe doing a dual fan conversion. I'll find out today. Seems the intercooler is blocking airflow.
Old Jun 30, 2009 | 07:31 AM
BlackZ51Vett's Avatar
BlackZ51Vett
If it starts fluxuating all over the place for no apparent reason (no loss of coolant, radiator not blocked. temps the same) could be a sign of a sticking thermostat.......
Old Jun 30, 2009 | 09:01 AM
BLACKJACK08
the thermostat was done over a year ago and its not leaking from there. i have a manual 6 speed. the temp would not be that much of a concern by running at 180 0r so except that it always ran at 172. the temp outside has been the same. on the hotter days in stop and go traffic it went to 212. what would cause the sudden change? once the thermostat opens fully isnt it always open. thats why i am not sure it could be a sticky therm. i think it would get much hotter if it wasnt opening fully. could the computer adjusted the timing, when i accelerate the temp climbs much quicker.
Old Jun 30, 2009 | 09:42 AM
nwc6's Avatar
nwc6
Probably thermostat binding and only opening 90%. My 160 runs 178 on a typical 80 degree day, and maybe 195 in traffic.
Old Jun 30, 2009 | 09:51 AM
achilds's Avatar
achilds
Take it out and check it in hot water to see when it opens. I bet the tstat is not working properly. After you check it post the what you see. It is failry straight forward to take them out and replace them.
Old Jun 30, 2009 | 10:46 AM
DSOMvette's Avatar
DSOMvette
St. Jude Donor '09
Old Jun 30, 2009 | 01:12 PM
BLACKJACK08
thanks for the replies. thats was my next step, might as well eliminate that since it is the easiest to do.
To coolant temp question
