Cam installation question ?
Old Jul 2, 2009 | 09:09 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Default Cam installation question ?
IM finally getting my CAM installed this weekend. I do however have some concerns about weather you need to remove the condenser and recover the refrigerant or just simply push the condenser out of the way and the CAM should just clear as my mechanic tells me ? Also on installing the 25%
powerbond underdrive pulley my mechanic does not recommend pinning the crank. He fells that its only necessary for supercharged engines and
my build will fall short of 500 rwhp. I know some of you guys did not pin the crank/pulley and had no problems. Am I being overcautious by insisting
it be done in spite of his objections. Would appreciate comments from those who have " CAM ONLY " & "H&C" Thanks, leon
Old Jul 2, 2009 | 10:25 AM
Spectrel's Avatar
Spectrel
I just did my cam install about three weeks ago , I trailered my car to the shop about 3 hours away, had the install done and towed it back. They did a street tune and the usual dyno pulls with no problem. After I got it home I drove it for the day and boom both my belts go simultaneously. My main pulley walked out (causing both belts to hit each other) when the crank bolt un torqued it self. The shop confirmed they installed the pulley correctly and re assured me it was just a fluke incident. This was a reputable shop that has done TONS of quality work for many members and I was confident this was not their fault.
I had to tow it all the way back and they fixed it at no charge (stealership wanted 900$ to do it). It doesn't happen often but is it really worth the risk considering how much of a PITA it is to get access to the pulley bolt? I decided I may as well go with an U/D pulley since they were in there and chose a power bond (SLP) 25% pulley and pinned my crank. I picked up 10 rwhp and 9 rwtq.
Chances are , you would be fine not pinning your crank, but you never know. Hope this helps and let us know how the install goes, I LOVE my cam !!
Old Jul 2, 2009 | 10:39 AM
ShinodaVette's Avatar
ShinodaVette
You do not have to remove the condenser. It is a bit tight convincing it to move downward and out of the way but it can be done. I just did mine about a month ago.
Old Jul 2, 2009 | 12:15 PM
LSCHLEM's Avatar
LSCHLEM
Thanks for your input. I want the pulley pinned. Dont want to take the chance of something happening in that area. My mods will be pretty much the same as yours. 450 would be nice as it would put me in zo6 territory and I have the 4.10 rear. How loud is it with the STINGERS. I have them too ?
Old Jul 2, 2009 | 12:49 PM
Spectrel's Avatar
Spectrel
Well the car sounds absolutely AMAZING. I get comments all the time on how good it sounds. Only problem is it drones like crazy. Now I'm 24 so this doesn't bother me all that much, and when your roof is out it's at least tolerable but I'm thinking about going to a B and B Fusion setup. Not everyone is a mod crazy vette owner and isn't wiling to deal with drone all (luckily my gf doesn't mind it too much). With the MN6 you can get out of it but more often then not there is a lot of drone. My only fear is that the fusion won't sound as good.
Also 450 is pretty doable, I had a 91 octane tune which leaves a little bit on the table. The tuner didn't feel the G6X3 was the ideal cam for my setup and was better suited to the LS3 with more cubes but obviously it does make good power.
Here is my dyno vid, the shop posted it for me (no it's not a C5):
http://www.youtube.com/watch?v=l4G3h...e=channel_page
I do have a lot more vids, but I haven't uploaded them yet.
I know you have probably read about the timing chain breaks lately, so go with the double roller timing chain. I don't think I have ever read about one breaking.
Old Jul 2, 2009 | 01:14 PM
SpinMonster's Avatar
SpinMonster
Leon, pin the crank.
I'm sorry you didnt wait for me to be back in the NE in August. I would have loved to hang with you and help with installing it.
What cam are you putting in?
Maybe I will help with heads next go-around.
Old Jul 2, 2009 | 03:29 PM
LSCHLEM's Avatar
LSCHLEM
Awsome dyno pull. I was also contemplating on the g6x3 in the ls2 with the ported fast. I kind of did my build in baby steps watching closely what was working then put it on and wow each time and ended up with
408 rwhp/412 rwtq on the dynojet. The idea of a CAM scares me as I remember back in the 70's when we put cams in and the car ran worse.
Bigger is not necessarily better and thats why I waited so long. The stingers are awsome now but it backfires on decel and I have the 1500-
1600 drone just like you do and I know it will get worse and perhaps I
will eventually go to npp's. I would like to hear yours idle in a vid if you
make one.
Old Jul 2, 2009 | 03:39 PM
LSCHLEM's Avatar
LSCHLEM
SPIN, I went with the Craigster CAM. Ididn't see anyone produce better
cam only numbers with the 230 XFI. A local guy with good experience on
lsx Corvettes will be putting in the 232 xer. However he will not be doing the final tune on the dyno. Ill be contacting you in that regard to get a
canned tune or some other arrangement using HP TUNERS.
Old Jul 2, 2009 | 03:40 PM
Spectrel's Avatar
Spectrel
Sure, I'll see if I can do one once the weather gets better. This car sounds very similar to mine at idle, it has the same cam and stingers the LS3 changes it but not as much as you'd think. I'd also like to mention that the drive ability is very good with this cam, you def know its there but once tuned correctly it was nice a smooth even at lower RPMs.
http://www.youtube.com/watch?v=k2-4A...layer_embedded
Take a look at this thread for another G6X3 LS2 install:
http://forums.corvetteforum.com/c6-t...3-456rwhp.html
Old Jul 2, 2009 | 05:54 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
If you want a dyno tune let me know. Im not too far from you.
Old Jul 2, 2009 | 11:07 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I had Stingers on my c5 h/c car...it was too much. Way too loud! I went with cutouts and stock mufflers this time so I can have loud or quiet my choice. I love them.
Old Jul 3, 2009 | 07:10 AM
LSCHLEM's Avatar
LSCHLEM
Joe, I love the setup you have with the cutouts. There is nothing better.
In PA we have a law on the books specifically prohibits cutouts that goes back to the 60's when we welded a bypass on the pipe and capped it with a plate. We would then remove it at the drag strip and put it back on for
street driving. I think they called the setup " LAKERS" for our older CF
members may bring back memories.
On the other hand what kind of numbers IYHO do you think ill come in at.
Thanks for your suggestion , Leon
Old Jul 3, 2009 | 08:53 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Hmm... I wonder if the NPP or Z06 muffler bypasses would technically pass that law? I'd recommend them. I can't use them due to my trailer hitch for towing race tires.
I imagine you'll come in at around the 445/420 range...the car will really come alive at 4500, you're gonna like it. And the sound...
Old Jul 3, 2009 | 09:12 AM
LSCHLEM's Avatar
LSCHLEM
Joe, NPP systems would work because the exhaust is still comming out the back and a z06 catback will still give it some sound and be perfectly legal.
The 445 would be ok however I would like around 432 rwtq. If not we will get it on the next go around.
Old Jul 3, 2009 | 10:37 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
The Z06 system will be a great option for you, and you can pick up the mufflers used at good prices now and have an exhaust shop put them on. You'll be able to sell your stingers and recoup most of the cost. You may like the stingers.....but I'm betting they'll be too loud for you.
Are you putting heads on the car? I think 432 tq out of a ls2 on a Dynojet will be a little tough to get with stock heads. I HIGHLY recommend you use Cometic .040 gaskets to increase the compression to about 11.4, that'll help a lot and since you have to change springs anyway, pulling the heads isn't a lot more money.
But don't get hung up on a number. Your car is gonna feel and be fast.
The key is having a SHARP tune so that your car drives like stock. It's pretty easy to do with our computers, easier than the LS1 computers for sure.
Old Jul 3, 2009 | 09:36 PM
superdutymike27's Avatar
superdutymike27
I too am getting a cam install next weekend at a local shop in Illinois. I left the set up to the shop to decide. I do know I am getting Melrose headers, Halltech intake and B&B Bullets. Not sure what kind of cam I am getting? I explained to them I wanted it to sound more or less like a pro stock car. This a very reputible shop and do great work. Do you think they will know to pin the pulley and the double timing chain items?
Old Jul 4, 2009 | 09:12 AM
LSCHLEM's Avatar
LSCHLEM
Some shops do and some dont. I would insist on it being installed at the time of the cam install. Its too much cost to do it later on.
BTW I did not mention that the TIMING CHAIN im using is the IWIS C5R
and it is prestreched from the factory. I got mine from KATECH as there
are cheaper versions of the IWIS chain out there. Good luck on your build. Leon
To Cam installation question ?
Old Jul 4, 2009 | 11:04 AM
superdutymike27
Thanks Leon.
I'll post the numbers after it's dyno tuned. I'm thinking somewhere around 400 hp at the wheels when it's complete?
Old Jul 5, 2009 | 08:41 AM
LSCHLEM's Avatar
LSCHLEM
Thanks Leon.
They should be able to get a good bit over 400rwhp. The good news is you have room for more be getting a ported fast and of course you will need a retune but thats down the road.
Even after the CAM install it would be easy to pull the heads and do another 30 rwhp through increases in compression and port work like
in C&C route. Good luck with your build, Leon
Old Jul 7, 2009 | 06:39 PM
superdutymike27
Leon.
I spoke to the shop today and asked them to pin the crank and they had explained to me that they normally don't unless it's a blower install. I did however talk them into it. The car goes in this Friday for the cam.
