157 degree temp. with new tstat ...
Old Jul 8, 2009 | 11:12 AM
Stingbill's Avatar
Stingbill
Default 157 degree temp. with new tstat ...
A few weeks ago I got a mail order tune and I install headers with
a X pipe with Z06 muffler and a M2W and a CAI.. the tuner supplied
a 160 tsat but when I run on the highway my temp is only 157 so
I`d like to change it,I sent an email to the tuner with no response for
now...could somebody tell me the part number for a new tsat !
I`ve search for some but they are for a LS1, I need one for a LS2
maybe there the same ? Mr Gasket 6367 is that a good number!
Thanks alot !
Old Jul 8, 2009 | 11:44 AM
Shrike6's Avatar
Shrike6
Somba master
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
Did you test the thermostat in hot water to see the temp it really opens at? What temps do you see around town and in traffic?
PM sent.
GM
Old Jul 8, 2009 | 12:34 PM
Sativa's Avatar
Sativa
It definitely sounds like your thermostat is messed up. I have a Lingenfelter 160 Thermostat and it runs at around 172 on the highway. Part #L310015204.
Old Jul 8, 2009 | 12:40 PM
JRHAWK9's Avatar
JRHAWK9
I have an SLP one and it runs mid 170's on the highway. Your's is definately opening too soon.
Old Jul 8, 2009 | 12:56 PM
Stingbill's Avatar
Stingbill
PM sent.
GM
No I did not test the tstat before I installed it...
The highest temp I have once seen in traffic is 172,It`s usually
always at 157 no matter what kind of driving !
I`m I leaving HP on the table and can I hurt the motor with that low ?
Old Jul 8, 2009 | 01:05 PM
nwc6's Avatar
nwc6
My MR Gasket 6367 runs 178 on the highway..Be sure to check it before installing.
Old Jul 8, 2009 | 01:29 PM
HITMAN99's Avatar
HITMAN99
If you do test it, use a pan full of coolant, not water. Also be aware that a 160 thermostat will just barely be open at 160 degrees, and may not be fully open even at 180 degrees.
Old Jul 8, 2009 | 01:31 PM
Shrike6's Avatar
Shrike6
Somba master
Ah... 160 degrees in water =160 degrees in coolant, right? or am I missing something?
GM
Old Jul 8, 2009 | 05:31 PM
Stingbill's Avatar
Stingbill
Thank`s everyone for yor help
Old Jul 8, 2009 | 05:37 PM
6Speeder's Avatar
6Speeder
6367 is the right one, should cruise @ 175 to 185.
Old Jul 8, 2009 | 06:19 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Most 160 STATS run around 180 which is desirable. You should test it
or at least have someone test it. On my 160 I on occasion I get up to 194
in traffic on a hot day.
Old Jul 8, 2009 | 06:27 PM
knkali's Avatar
knkali
GM
my thoughts too
Old Jul 8, 2009 | 07:31 PM
pmj341's Avatar
pmj341
that is what I see with mine_180
Old Jul 8, 2009 | 10:43 PM
RAT_FINK's Avatar
RAT_FINK
sounds like the stat failed after install. likely due to install snafu...how was it installed ? or should i say the process in which system was burped and or checked for air pockets?
Old Jul 9, 2009 | 07:50 AM
DSOMvette's Avatar
DSOMvette
St. Jude Donor '09
Thats exactly where mine cruises at.
Old Jul 9, 2009 | 07:57 AM
LSCHLEM's Avatar
LSCHLEM
Default Fan speed ?
Another thing we forgot to mention here is that the fan speed should be programed in. Yes that is very important and maybe your fan is running all the time to stay at 157 ?
Old Jul 9, 2009 | 07:59 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Several others have reported in the past that the Mr Gasket stat runs around 160, while the Moto-Rad brand, as sold by many suppliers, run around 180 at cruise.
I'd swap it out for a Moto-Rad "160" unit.
Old Jul 9, 2009 | 09:13 AM
JRHAWK9's Avatar
JRHAWK9
I agree. My SLP (re-packaged MotoRad) runs ~175°-180° on the highway.
Old Jul 9, 2009 | 10:14 AM
FloydSummerOf68's Avatar
FloydSummerOf68
If you do test it, use a pan full of coolant, not water. .
lol
To 157 degree temp. with new tstat ...
