Overheating
Old Jul 10, 2009 | 03:36 AM
Dealripper's Avatar
Dealripper
Default Overheating
My C6 is overheating. The belt and hoses are OK. I turned the AC on however the fan does not come like it used to do after sitting in traffic for a while. Any suggestions?
Old Jul 10, 2009 | 06:56 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
many have fixed it with a reflash of the ecm
Old Jul 10, 2009 | 07:37 AM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
What temps ahave you seen??
I had a symilar problem, but I had a separate control switch, found the fan controler plug by the radiator had gotten hot and loose causing a lot off resistance, as soon as I cleaned and tightened the fit it was fine.
hope this helps
Old Jul 10, 2009 | 08:12 AM
C6~Missle's Avatar
C6~Missle
check fuses and fan relay
Old Jul 24, 2009 | 07:46 PM
Dealripper's Avatar
Dealripper
Default Overheating
The problem was a shorted wire. Thanks for all of the help from this great forum and it's members.
To Overheating
