20 in rims
Old Jul 16, 2009 | 04:42 AM
pinky balls's Avatar
pinky balls
Default 20 in rims
hell all my good people,just purchased the american dream 2009 c6 my question is, running a 20x9 in front 20x11 in rear three piece forged wheels, is that a bad idea because i like to drive fast and if this combo is to dangerous please let me know. don't like the look of 19 - 20 combo.
Old Jul 16, 2009 | 05:44 AM
SpinMonster's Avatar
SpinMonster
I wouldnt say its dangerous but its all show and no go. There arent any performance tires available for a 20" rim that will have any real traction. Nitto makes a 305/20 drag radial but its not going to handle well and thats it for performance tires. Outside of that you will be lighting up the tires with 400HP in 3 gears. A friend had a 345/20 in the rear with 420rwhp and they lit up in 3 gears. The tire was a nitto Invo which is quite possibly the worst performing tire/size I had ever seen. I think stock runflats are better. I really cant deal with bling and no performance. Its like having a 6cylinder corvette.
The best tire size for real handling and traction is 18" all around.
Old Jul 16, 2009 | 12:15 PM
Mrs. CoW's Avatar
Mrs. CoW
Originally Posted by pinky *****
hello all my good people,just purchased the american dream 2009 c6 my question is, running a 20x9 in front 20x11 in rear three piece forged wheels, is that a bad idea because i like to drive fast and if this combo is to dangerous please let me know. don't like the look of 19 - 20 combo.
And, if you do change the tires, don't forget to "tell" your car that, otherwise your speedo (i don't mean you bathing suit ) will be off.
If you want to go fast you'll need a good tuner to tune your car and do some performance mods.
Give Chuck CoW a call, he's a supporting vendor here on the forum also he is a very well known and knowledgeable tuner and will be more than happy to answer any questions you have about the car. Here is his number 914-332-0049
Mrs. CoW
Old Jul 16, 2009 | 12:43 PM
blocc monster's Avatar
blocc monster
Me and my buddy have 20s and u can drive it just the same as stock. Everybody whos says no have not had any on there car, and the speedo thing is b.s.
Old Jul 16, 2009 | 05:07 PM
pinky balls
Default 20 in rims
first thanks 4 your input, second how does it drive with the 20s how fast did you go with them, what's people talking about with the traction control not working right and the speedo am i better of just keeping the stock
Old Jul 16, 2009 | 05:30 PM
TMRoc's Avatar
TMRoc
I changed to 19s in the front and 20s in the rear mostly for bling. (I have 18 all around that I use also) You can tell its a little heavier/slower from dead stop. As far as handling i haven't seen/felt any major differents. Top speed well I was on a closed road setup for high speed runs and I hit 140 with not problems with plenty left, turns, flat straightaways, small hills.. I had not problems. However, the same road with the 18s on the car felt much quicker. Handling was about the same.
Old Jul 16, 2009 | 09:43 PM
SSJCreeper's Avatar
SSJCreeper
I had 19x10 and 20x11 CCW's on my '06. Speedo will be fine provided you do not change your overall diameter. Traction control and all nannies will work provided you get wheel sensors and resync to car. Actually, you loose the ability to turn them all completely off if you don't get sensors.
To Spin's point, traction was limited with my supercharger combo, but it greatly improved when i switched over to 325/25/20 Pilot Sport 2's out back. For my money, that's about as good as it gets for the 20" wheel right now. The rear would still wiggle a little in 3rd, but not totally rip loose like it would with the stock runflats.
Old Jul 16, 2009 | 09:53 PM
pinky balls
Default 20 in rims
so if i run 20x9 in front 20x11 rear ill be all right o yea the car is automatic will tc act up
Old Jul 16, 2009 | 10:09 PM
SSJCreeper's Avatar
SSJCreeper
Yep, you can run that combo. The 20" wheel at all corners seems to be popular with some of the Z06 guys. Offset is the key thing to look out for. You'll want to make sure they don't stick out of the fenders. Traction control should not be an issue. I ran a set of wheels for a while without sensors. Traction control still worked, however I could not disable active handling and traction control without having the sensors.
Old Jul 17, 2009 | 06:20 PM
srobert910's Avatar
srobert910
Can't hook up on 20" rears? So why does the ZR1 come stock on 335/25/20 rear tires? Must be all show and no go right?
Old Jul 17, 2009 | 09:30 PM
excessive81's Avatar
excessive81
have been running zr1 size wheels and tires for 4 years now on my o5...zero issues. of course 18 dr would hook better....but with my power level blowing the tires off saves my drive train lol
To 20 in rims
