Check Gas Cap Message
Old Jul 16, 2009 | 10:25 AM
Rscha60's Avatar
Rscha60
Default Check Gas Cap Message
I'm getting a repeated "Check Gas Cap" message every time I start up and after I clear it, again about 15 mins later. Of course the gas cap is checked and on correctly. Has anyone seen this? 2005 Z51, manual. Vararam, throttle body spacer only mods done when this started, but not immediately following. A couple of thousand miles later, so I don't think it is related.
Old Jul 16, 2009 | 12:01 PM
Fore58's Avatar
Fore58
It happened to me....it's a recall. Go to the dealer and get a replacement. With your new cap, it will probably take a few days before the computer recognize.
Old Jul 16, 2009 | 02:44 PM
VET4LES's Avatar
VET4LES
No charge, can't beat that.
Old Jul 16, 2009 | 05:46 PM
TMRoc's Avatar
TMRoc
I seen somewhere on here to put a little WD40 or silcone on the rubber gasket and don't press down on it or tighten it too much when you put it back on.
Old Jul 16, 2009 | 08:07 PM
NOCRISIS's Avatar
NOCRISIS
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
happened to me on my 05,,,went to dealer got a new one,N/C,
Old Jul 17, 2009 | 11:44 PM
cstraley's Avatar
cstraley
Default Been there
The new replacement cap fixed the problem.
Old Jul 18, 2009 | 12:21 AM
keyplyr's Avatar
keyplyr
New caps were only a temp fix for me (got a couple from dealer.) After a week or two the error returned. Permanent fix was to have it turned off in the ECM.
To Check Gas Cap Message
