Little help with boost pump
Old Jul 16, 2009 | 07:15 PM
Norman Lane's Avatar
Norman Lane
Default Little help with boost pump
Just installed kenny bell boost a pump and now car will not start any suggestion on what the problem may be.
Old Jul 16, 2009 | 07:28 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
check the fuses. then make sure you got a good ground.
Old Jul 16, 2009 | 07:32 PM
Norman Lane
Fuse is ok and ground is ok, it appears that the relay is not kicking in.
Old Jul 17, 2009 | 09:48 AM
yellowc6ohio's Avatar
yellowc6ohio
check the relay mine burned up also you can swap it with fog lights or horn till you get a new one.
To Little help with boost pump
