Camshaft for 403 stroker
Old Jul 25, 2009 | 11:37 PM
vvette_c6's Avatar
vvette_c6
Default Camshaft for 403 stroker
will guys
with engine 10.9 Compression
59 CC heads
Stoker 403
what camshaft do u recommend ?
does LG G6X4 will work good with the car ?
Old Jul 26, 2009 | 11:14 AM
gtodoug's Avatar
gtodoug
I use the G5x4 in my car. the cam is not that large, although the lsa is really tight and makes for a wicked idle. Driveability is fine above 2000 rpms. It will tend to buck a little under that.
I removed a 244/250 114lsa cam that drove better, but had no power under the curve. I picked up 25-30wtq switching to the smaller cam.
If I had to do it all over again, I would go with something in the 236/240 range with a 113-114lsa to keep driveability and top end power up.
I had another stroker that I ran which used much larger cams and finally had success with a 244/248 grind from comp.
It would be nice to see a little more compression out of your setup if it was to be for all motor, is it?
Old Jul 26, 2009 | 12:52 PM
SpinMonster's Avatar
SpinMonster
What heads?
Old Jul 26, 2009 | 01:16 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
Feel free to PM me with your entire specs and i will custom grind you one.
Old Jul 30, 2009 | 07:19 AM
vvette_c6's Avatar
vvette_c6
my heads are 59 CC patriot
well i already placed the order
G6X4 for the camshaft ,, if i didnt like it i will pvt msg u thanks for help
To Camshaft for 403 stroker
