Ceramic pads? questions
Old Jul 29, 2009 | 12:25 PM
CLLOFF's Avatar
CLLOFF
Default Ceramic pads? questions
Have 10K miles on my 2006 coupe. It's a street car and daily driver for my short commute. Looking to switch to ceramic pads for lower dust and noise. But don't want to sacrifice performance either. If I can improve of stock GM that would be nice. I have Z51 rotors.
Seems the AC/delco, Hawk and Carbotech (least expensive to most expesive) are the most common ones mentioned on the Forum and the local auto parts stores sells genrics, which are cheapest.
Any differences I should be aware of? Appreciate any recommendations.
Can I just slip in the new pads or do I need to get the rotors turned or something else done?
PS: I added headers, CAI, exhaust, etc. for power so I'm not looking to skimp on brakes. That said I'm not a fan of wasting money either.
Old Jul 29, 2009 | 02:25 PM
marc8090's Avatar
marc8090
I went with the AC Delco ceramics and are totally satisfied. I will say right up front that I am not hard on my brakes at all. That being said they make very little dust and absolutely no noise. I notice no difference in normal driving as to how the car stops. Yes, they can be put on your existing rotors without turning as long as the rotors aren't warped and don't have any deep grooves.
Old Jul 30, 2009 | 10:52 AM
Bandit1's Avatar
Bandit1
Old Jul 30, 2009 | 03:32 PM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
I have to say it depends on your driving style. I switched to GM ceramics around 10k miles and they were great at first. When I finally got around to running the car pretty hard and doing a couple higher speed stops they faded pretty bad. I switched to the Carbotechs and have been happy ever since. I have about 8k miles on the Carbotechs and will use them again when I finally wear them out.
Old Jul 30, 2009 | 03:45 PM
Darrin@Darin U Performance's Avatar
0Darrin@Darin U Performance
Former Vendor
We can ship you the Hawk Ceramics for $179 to your door. PM me or give us a call at the shop at 281-345-4502...
Darrin
Old Jul 30, 2009 | 04:03 PM
YLOFEVR's Avatar
YLOFEVR
St. Jude Donor '09-'10-'11
Default Hawk ceramic pads
email sent.
Old Jul 30, 2009 | 11:45 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
I have sold 100's of sets of ceramic pads for C6's and haven't ever had any complaints. They are the best bang for the buck as well.
||--Ceramic Brake Pads--||
88909667 – Front ceramic pad kit
88909668 – Rear ceramic pad kit
Both front and rear ceramic pad kits 153.03 shipped.
Note: The ceramic pads are for stock and Z51 applications
Old Jul 31, 2009 | 12:19 AM
dsp300c's Avatar
dsp300c
put these exact ones on last night...works like a charm and a great price...thanks gene
Old Aug 2, 2009 | 10:51 AM
SubSolar's Avatar
SubSolar
I believe you will take a performance hit, especially when the brakes are cold. There's a reason GM used the pads it did, it wasn't because they wanted owners to have to wash their wheels more often.
Old Aug 2, 2009 | 12:32 PM
timd38's Avatar
timd38
Same here. I liked them so much that I put ceramic pads on all my cars the following week.
The pads are made by Raybestos, for what it is worth.
Old Aug 3, 2009 | 02:36 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Old Aug 5, 2009 | 11:53 PM
Gene Culley
Thank you for your business and the vote of confidence.
To Ceramic pads? questions
