NPP In a box question
Old Jul 30, 2009 | 07:43 AM
CFR5's Avatar
CFR5
Default NPP In a box question
I have ordered and will be installing a set of 2008 NPPs on my 2005 manual C6. My question is in regards to the NPP in a box. I have looked over the instructions about running the vacuum line from the fuse box to the trunk for a coupe, but I have a convertible...does anyone know or has anyone installed one on a convertible who could give me some direction on where/how to run the line from the fuse box? Thanks
Old Jul 30, 2009 | 07:56 AM
SonOfDreams's Avatar
0SonOfDreams
Former Vendor
St. Jude Donor '09
Could have just asked us
It's basicaly the same, I just did not have a vert to use for pictures but you will be able to run it using the same route, you just need to work around the top parts
Old Jul 30, 2009 | 07:59 AM
CFR5's Avatar
CFR5
Sounds good, thanks.
Old Jul 30, 2009 | 03:37 PM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
You are going to love this setup! I've had mine for over a year now and the novelty still hasn't worn off. This is, by far, one of the coolest things you can install on a C6.
To NPP In a box question
