manual trans atf
Old Jul 30, 2009 | 03:54 PM
g_vett's Avatar
g_vett
Default manual trans atf
my 05 manual transmission has never been a fun transmission to shift it is far to notchy. I changed to valoline mecon, but is still is not very good. Has anybody tried red line or royal purple or amsoil. what is the last word on this issue.
Old Jul 30, 2009 | 05:00 PM
c6 batmobile's Avatar
c6 batmobile
There is no last word. All three of the above products are great products rated within the top 5 of oils. I cant remeber the line off the top of my head but penzoil also makes a good one.
Begin the debate.......................
Old Jul 30, 2009 | 05:14 PM
REVAK's Avatar
REVAK
Royal Purple Syncromax..............
Old Jul 30, 2009 | 05:48 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
All the 3 you mentioned have been used by many with varying results. I switched to Amsoil and honestly can't tell much of a noticeable difference. I really don't think any fluids are going to make a drastic difference in shifting improvement.
Old Jul 30, 2009 | 06:10 PM
PeterM's Avatar
PeterM
Old Jul 30, 2009 | 07:53 PM
VET4LES's Avatar
VET4LES
Old Jul 31, 2009 | 12:34 AM
JayplaySS2's Avatar
JayplaySS2
Royal Purple Syncromax worked great after 3K miles on my KB Cobra with a hard shift. The original ATF fluid was perfect when I drained it FYI.
Just take advice from guys who have actually changed it
Old Jul 31, 2009 | 06:09 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
i changed mine to amsoil atf. im going back to the gm stuff tomorrow.
-carl
Old Jul 31, 2009 | 06:21 AM
timd38's Avatar
timd38
I use RedLine, but to be frank, I think it it shifts better, but I may be justifying the expense.
Old Jul 31, 2009 | 01:58 PM
g_vett's Avatar
g_vett
Default trans fuild
thanks for the infomation, I will leave the valoline mecon in the trans. on the same subject do any of you blip the throttle when down shift. I have noticed you get a better down shift to second.
Old Jul 31, 2009 | 04:28 PM
eddie_VETTEr's Avatar
eddie_VETTEr
Redline ftw...
Old Aug 1, 2009 | 03:50 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I use AMSOIL Torque-Drive Synthetic Transmission Fluid (product code ATG1G) in my daily driver, an 06 CTS-V with the same Tremec six speed as in the Corvette. This fluid does not have any viscosity improvers and will not shear down. Compare that to the factory fill fluid in my CTS-V which sheared down in viscosity to low out of grade in about 10k miles:
2006 Cadillac CTS-V Used Oil Analysis Dexron III vs AMSOIL ATF Transmission Fluid
Note that I used the AMSOIL ATF for about 7k miles and it did not lose any viscosity during that period. I switched ot the Torque Drive as AMSOIL changed their primary recommendation for the Tremec from the ATF to the Torque Drive. Both are very similar fluids, but I wanted to try the Torque Drive before I started recommending it. For what its worth, I've used the ATF in my Z06 since 2004 without a problem.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To manual trans atf
