Hp at the crank??
Old Jul 30, 2009 | 04:42 PM
MLCZ51's Avatar
MLCZ51
Default Hp at the crank??
440rwhp 401tq
how much hp is that at the crank???
Old Jul 30, 2009 | 05:32 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
probably around 500 based on what stock Z06's put down.
Old Jul 30, 2009 | 05:38 PM
kmthor00's Avatar
kmthor00
Auto- 440 at rear would be about 525 crank (17% loss)
manual- 440 at rear would be about 490 crank (10% loss)
Hope that helps (just a guide, not an exact measurement)
Old Jul 30, 2009 | 06:21 PM
BOB EAGAN's Avatar
BOB EAGAN
Originally Posted by MLCZ51
440rwhp 401tq
Auto approx. 505/466, manual approx. 495/456. Z06's usually run 440-450 rwhp. At on near 500 crank is as close as you'll get.
Old Jul 30, 2009 | 11:43 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
The rule of thumb that I've always understood is 15% drivetrain loss for manual and 18% loss for automatic.
Old Jul 30, 2009 | 11:45 PM
saplumr's Avatar
saplumr
Originally Posted by BOB EAGAN
Manual approx. 505/466, auto approx. 495/456. Z06's usually run 440-450 rwhp. At on near 500 crank is as close as you'll get.
Fixed it for ya!
Old Jul 31, 2009 | 06:36 AM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
Default Another variable
If you have 4.10 or 3.90 gearing I beleive the equation is different. Something about not being able to get a "good pull" with short gears.
Old Jul 31, 2009 | 12:16 PM
07MontRedcp's Avatar
07MontRedcp
440rwhp 401tq
Multiply those numbers by 1.12-1.15.
BJK
Old Aug 2, 2009 | 12:28 AM
MLCZ51's Avatar
MLCZ51
Default Et..
Originally Posted by 07montredcp
multiply those numbers by 1.12-1.15.
Bjk
z-51 6 speed on m/t dr's ..what will it run....with good driver?? 440 rwhp 401rwtq??
Old Aug 2, 2009 | 12:38 AM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Low-mid 11's....With a great driver and awesome weather, high 10's
Old Aug 2, 2009 | 02:27 AM
MLCZ51's Avatar
MLCZ51
Default cool air
40 degree weather, good 60 ft ..say 1.65 to 170 range i'm thinking 11.10 to 11.20's..
Old Aug 2, 2009 | 05:56 AM
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
Originally Posted by saplumr
Fixed it for ya!
Actually, you didn't. It was more correct to begin with. Actual flywheel/crank numbers would be higer for an Auto than they would for a manual. An auto sucks more power than does a manual. As an example, 500chp through an auto might read 425wheel, while 500chp via a manual might read 440wheel.
Old Aug 2, 2009 | 01:03 PM
YLOFEVR's Avatar
YLOFEVR
St. Jude Donor '09-'10-'11
Old Aug 2, 2009 | 02:13 PM
saplumr's Avatar
saplumr
Huh! I think you're right. Sometimes the mind is a wonderful thing and other times it's nothing more than a trap. Obviously my comprehension skills were slightly off.
Old Aug 2, 2009 | 04:48 PM
mvcrash's Avatar
mvcrash
The fact of the matter is that HP loss through the drive train is not linear. The faster the engine revs, the less loss through the drive. Consult your local Mechanical Engineer for further information.
That is all.
Old Aug 2, 2009 | 04:56 PM
trapp's Avatar
trapp
440rwhp 401tq
My 07 Z06 stock was 436rwhp so based on that about 500hp
Old Aug 2, 2009 | 09:35 PM
BOB EAGAN's Avatar
BOB EAGAN
That is all.
I'm not a mech. engr., so what you say is probable true. We are not looking at drivetrain loss at 2000, or 3000 or 4000 rpm.The dyno tests we use to compare max hp and max tq and the max hp usually occurs in the 5500 rpm range for stock cars and 6000-6500 for cammed cars. Most all the cars in this forum are in this range, and the hp loss on the ls2, ls3 and ls7 at peak hp is approx. 55 for manuals and 65 for autos. These are dynojet numbers are it works out very close for n/a engines. Any comments are always welcome.
To Hp at the crank??
Old Aug 2, 2009 | 09:40 PM
BOB EAGAN's Avatar
BOB EAGAN
Everyone pretty much agree on 500 crank. I know the z06 has good rwtq. numbers, do you happen to remember what yours was?
Old Aug 3, 2009 | 02:03 PM
MLCZ51's Avatar
MLCZ51
Default Ccw drag pack added..
10.98@128MPH.. 1.61 60FT. WAS THE BEST PASS...
Old Aug 3, 2009 | 02:37 PM
BOB EAGAN's Avatar
BOB EAGAN
Very nice run. Great trap speed and the 10's must make you "FEEL PROUD".
