how much air when autocross ?
Old Jul 30, 2009 | 11:33 PM
NARIMAN's Avatar
NARIMAN
Default how much air when autocross ?
how much air should i keep in tires when i autocross?
Old Jul 31, 2009 | 12:42 AM
glennhl's Avatar
glennhl
I started at 40 in the front and 35 in the rears with Supercar Runflats. The car pushed like a pig. The runflats have a very stiff sidewall and I guess they don't need as much pressure. I found the best was around 33 in the fronts and 32 in the rears. Car turned in much better.
Old Jul 31, 2009 | 12:50 AM
glennhl's Avatar
glennhl
Also, use some chalk and mark the sidewalls where it meets the tread. If the pressure is too low, the tire will roll over onto the sidewall and rub off the chalk. If the pressure is too high, it won't roll over at all. The trick is to use up the whole tread including starting to just go over the edges. I'm probably not doing too well describing it, but if you ask a veteran, they will show you what to do when you are at the autocross.
Old Jul 31, 2009 | 03:00 AM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
30 or less imo
Old Jul 31, 2009 | 09:18 AM
Wah's Avatar
Wah
Rule of thumb: the lowest pressure before the sidewall rolls. This may depend on your racing habits, the surface conditions and the course lay out.
Old Jul 31, 2009 | 11:28 AM
Pylons's Avatar
Pylons
and that will depend on things above as well as the tire you're using...e.g., a runflat probably doesn't need much more air than street pressure because of the stiff sidewalls, while another non-RF might need 10 more lbs
if you're new at it, err on the high side and worry more about your driving than a few psi in the tires
Old Jul 31, 2009 | 01:17 PM
Hot Rod Todd's Avatar
Hot Rod Todd
I was running stock 30 lbs (cold) but went to running 38F 36R (hot). It seems to handle better and provide less wear on the edge of the tires. Rollover checks are useful with regular tires, but I don't think you see much difference with the stiff run-flats.
Old Jul 31, 2009 | 02:13 PM
DarthStimpy's Avatar
DarthStimpy
on my 05 i ran 36 F / 34 R.
this gave me a nice, slightly over steer feel. which I prefer.
Depending on how many runs you get, i would suggest starting at 36, do a run, and then go down a psi, then another and see if you get faster.
If this your first season, just put the tires at 35psi and drive. Lack of consistency will make it impossible to dial in the tires.
Old Aug 1, 2009 | 10:55 PM
goatts's Avatar
goatts
Rule of thumb is 40. You can back off from there watching the rollover. I have found 40 to be too much.
To how much air when autocross ?
