Nav Disc Question
Old Jul 31, 2009 | 10:49 AM
rikhek's Avatar
rikhek
Default Nav Disc Question
I just bought an 08 C6 and am wondering why it has 2 nav discs when other GM vehicles come with a single? WIll the single work as well? I recently bought a used C6 that didn't have the original discs. The seller gave me a single disc that coversw the entire country and it "seems" to work.
I'm not at all impressed with the quality of the display and not sure if ?????
Here's what it looks like. It's GM Part #15932106; Version 3.00
Would somebody take the time to educate me.
TIA.
Rick
Old Jul 31, 2009 | 10:56 AM
Walt White Coupe's Avatar
Walt White Coupe
I believe it was the 08 model that came with two discs, one for the east and the other for the west with overlap in the middle because the data could not fit on one disc. Either the one disc or the two disc set will work in any year C6.
Old Jul 31, 2009 | 11:21 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
As they add data to it, it simply all will not fit onto a single disk any more. Now what they need to do is alter the DVD ROM to a BluRay and they'll have lots of room but of course the disks won't be compatible with the current ROM drives in our cars.
Old Jul 31, 2009 | 11:29 AM
rikhek's Avatar
rikhek
So if I'm out driving country roads and jumping back and forth across the border every 5 minutes from Arkansas which is say on disc 1 and Oklahoma which is on Disc 2 do I need to constantly change discs?
Rick
Old Jul 31, 2009 | 01:07 PM
dgrant3830's Avatar
dgrant3830
No, the roads should be the same on both disks. Most of the data change is the information for businesses, phone numbers and etc..
Old Jul 31, 2009 | 02:30 PM
DarthStimpy's Avatar
DarthStimpy
Both Disks have all of the road information for the USA and Canada, but only have POI info for 1/2 of the country.
Old Jul 31, 2009 | 03:00 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Map Data is identical on both discs - only POI (Points of Interest) information is different for East/West.
Old Jul 31, 2009 | 04:24 PM
rikhek's Avatar
rikhek
Thanks guys.
Old Aug 1, 2009 | 08:33 PM
Fordan's Avatar
Fordan
Rick
Also note from the map that there is there is overlap between the discs, so unless you're going through several states, you shouldn't have to swap discs even for POI info.
To Nav Disc Question
