Rocker Arm Modification?
I pulled the valve covers and at first didn't see any issues, but then noticed that edge of at least 3 of the spring retainers had small indentations. All of them looked like they were very close to making contact in the same way. Prior to the rebuild I had been running the same valve/spring setup with the stock rockers with no clearance issues. My theory is that the grind for the new valves lowered the seat just enough to allow the valve and spring to come up high enough to cause a clearance issue with the stock rocker arms.
Aftermarket rocker arms seem to be on the more expensive side of things and I'm not looking to do anything but deal with the clearance issue. I recall seeing something on the board about someone removing a slight amount of material from the rocker arms (but cannot find it with the search tool). In my case I would need to remove about 1mm from the thickest part of the arm. Had anyone does this, or heard about successes or failures as a result? Will any modification to a part such as this do any more than just proportionally reduce the strength of the part?
Come to think of it there must be some small amount play in the lifters when the valve is fully closed. If there wasn't you would risk not allowing the valve to completely close. If this is true then moving up my rocker might actually bring me closer to my original lift numbers (right now I probably have more lift than before) Can someone who understands this comment on my ideas?
908-317-4496
www.cartek.net
