Auto trans swap questions....?
Old Aug 3, 2009 | 05:42 PM
lfsglass's Avatar
lfsglass
Default Auto trans swap questions....?
What is the difference between the 4l60e in the C5 corvette and the 4l65e in the '05 corvette? It seems like common practice these days to swap the mn6 trans (Z06) for an auto trans when drag racing is the chosen past time.
Is the C5 trans the better choice or is the '05 C6 trans better?
Old Aug 3, 2009 | 06:23 PM
mitchell c's Avatar
mitchell c
The A6 tranny found in 06 and newer vettes is better than than the A4. I believe the A4s found in the C5 and the 05 C6 are pretty much the same tranny.
Old Aug 3, 2009 | 06:46 PM
lfsglass's Avatar
lfsglass
I don't think anyone offers the "upgrade" parts for the A6 trans yet (it won't hold up as well to higher levels of HP) and I've heard the 4l60e is better suited for the drag strip.
Is the C5 (4l60e) auto trans and the '05 C6 (4l65e) auto trans similar......which is better?
Old Aug 4, 2009 | 12:05 AM
quick Ag's Avatar
quick Ag
The 4l65e was developed with a five-pinion planetary gearset as opposed to the four-pinion setup in the 4l60. The 4l65 also has teflon washers in between the gearsets, the 4l60 does not. The extra gearset and teflon washers allows the 4l65 to withstand a greater level of torque and operate at higher speeds than the 4l60.
Old Aug 5, 2009 | 05:10 PM
lfsglass's Avatar
lfsglass
Which would be the wiser choice when converting the C6Z over to the auto trans? Is one easier or more straight forward than the other?
Old Aug 6, 2009 | 02:22 AM
quick Ag's Avatar
quick Ag
In my unprofessional opinion I would say the 4L65 is the better choice simply because it was developed to handle more torque and higher speeds than the 4L60. A stock 4L65 would stand up adequately behind the LS7, but for rock solid reliability you should give the guys at RPM transmissions ( forum vendor) a call and ask about their level IV and V 4L65 automatic transmissions. Their transmissions will more than suit your needs.
Old Aug 6, 2009 | 07:38 AM
TMRoc's Avatar
TMRoc
check with RPM. Maybe they will come on here and teach us all about the two trannys.
Old Aug 6, 2009 | 11:36 AM
lfsglass's Avatar
lfsglass
I Pm'ed Todd @ RPM:
I have a thread started and it seems to be a topic of interest:
http://forums.corvetteforum.com/c6-t...questions.html
Would you mind explaining which of the two options would be the wiser choice?
The C5 components or the C6 components.....what is the difference between the trans, torque tube, bellhousing, flexplate, collar, ect.
What parts are needed to convert the C6Z to a 4l60e/4l65e auto trans?
Thanks,
Steve
Old Aug 6, 2009 | 06:12 PM
c6 batmobile's Avatar
c6 batmobile
The a4 is the same in C5 and C6 but the spline for the rear end is different I believe. The A4 is better for drag racing as its much easier to plot the shift points etc. It has also been proven to last as the A6 still has a way to go. Your going to get a lot of a4 haters and 05 c6 haters in general who are going to have a biased opinion just because they paid more for their cars.
Old Aug 6, 2009 | 08:01 PM
lfsglass's Avatar
lfsglass
I'm definately going for the A4 trans......
Thought I'd have more people who have researched this or actually done this conversion chiming in. I'd like to know what is needed to complete the conversion and if the remaining parts needed are the same from a C5 as a C6.
Is the spline in the C5 different than the C6? Is the spline from the C6 different from the C6Z?
Maybe this is in the wrong section.....?
Old Aug 6, 2009 | 08:58 PM
dennis50nj's Avatar
dennis50nj
I'm definately going fpr the A4 trans......
i think the c5 and the c6 there is a lot different the converter from a c5 wont work on a c6, the tcm is in the trans
Old Aug 6, 2009 | 09:20 PM
LS2POWA's Avatar
LS2POWA
Ive talked to a local shop about how and what they would use in the C6Z swap to auto, and I mentioned using a 4L80e, and they replied back saying they only use the 6L80e(A6) in their swaps.
RPM does have a modified A6 tranny now from last I read. Not sure on the power ratings though.
Best thing of using the A6 over the 4L60/65 would be still able to "shift" with the paddle shifters.
Old Aug 6, 2009 | 10:27 PM
lfsglass's Avatar
lfsglass
No paddle shifters in the Z.....didn't plan on setting it up like that. I think the gears are a tad too close in the A6 for drag racing....? I didn't want to go the 4l80e direction b/c of chopping the car up......I guess you decided to keep the m6?
I wish RPM would chime in and offer some helpful advice................
Old Aug 7, 2009 | 12:00 AM
LS2POWA's Avatar
LS2POWA
I have a blown/stroked C6 right now with an A6 (stuck with autos due to a bad accident).
Plan to sell mine to buy a 06 Z though and just do the A6 swap and call it a day.
Old Aug 7, 2009 | 01:07 PM
lfsglass's Avatar
lfsglass
Well can you hurry up.......
So you can answer all of my questions !
Old Aug 7, 2009 | 01:10 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
I've already sorta done one as I'm running a cammed LS7/A6 combo in my 1LT 07 as we speak.
Christopher
Old Aug 7, 2009 | 02:12 PM
Ragtop 99's Avatar
Ragtop 99
I'm fairly sure that I've seen others post about doing a 4L80 swap in the C6. If you plan to put down serious power, the 4L80 deserves a close look. Over the years I've seen a lot of so-called "built" 4L60's break, especially ones that are shifted at 7000 rpm or higher.
To Auto trans swap questions....?
Old Aug 8, 2009 | 02:10 PM
lfsglass's Avatar
lfsglass
I hate the idea of cutting up the car to make it fit ......still in the back of my mind though.
Anyone have first hand knowledge of how susceptible the 4l60/65's are to damage? Any idea on the reliability of the A6 in high HP applications?
Old Aug 12, 2009 | 08:14 AM
todd@rpmtransmissions's Avatar
0todd@rpmtransmissions
Former Vendor
Sorry for not posting earlier. TJ has been gone for a week and a half. He will be back in tomorrow. If you could give him a call, he can explain all the differences, and the benefits. He can also give you a price on the components, or us doing the swap. We've done quite a few of them now, and have many different options.
Todd
Old Aug 12, 2009 | 02:05 PM
tluck's Avatar
tluck
I'm currently using a an RPM Level 6 4L65 in my 402 stroker/nitrous 2006 C6. My 1/4 time with 2 100 shots was 9.65 @ 141 MPH with 373 gears. I plan to use 2 150 shots this Friday @ the local 1/8 track. The 4L65 trans. has operated perfectly. Within the next 2 months a 440" LSX with a 88 mm turbo, DTE built Z06 3.42 rear, RPM 4L80 trans., and many other changes will be installed in my car. Mayhem Motorsports in Raleigh, N.C. DOES ALL MY WORK. People in the vacinity of Raleigh please consider Mayhem for your needs Their # is 919-852-3766.
