Need help asap! Key prob..
Any way took intake tubes and bridge off to inspect and clean MAF. Put everything back together, and hooked power back up. Got my fob to open doors and nothing. Like as if the car was dead. I had no manuel key, so it was a trip x2 to the dealer to Have a key cut, twice. It didnt fit the first time. They said if it dont work this time call a locksmith. My question is there another way to make it inside to program my fobs? Or what else can I do to fix this issue? PLEASE HELP!!
CHAD
If your Fob was working but the car's battery died, and you didn't have your key to open the hatch, you could jack up the right front of the car to access the starter and a ground to hook up jumper cables or a charger to power up the electrical system and then use the Fob to open a door.
If you need to program a Fob, take a look in your owner's manual and you'll see that, IIRC, you need a working Fob and you also need to insert the key in the hatch lock and turn it during the Fob programming procedure.
So.....with an inop Fob and no key, you're screwed!!!
Bob
But, with an inop Fob, what did you do from there???
Did the Fob work when put into the glove compartment slot???
I've never needed it, but I always carry a key with me in case I have a situation like yours. When I travel I take both Fobs with me.
Everybody should check their key every once in a while to make sure the cable from the lock above the license plate to the latch in the cargo compartment is working properly. The end of the cable that attaches to the latch has a ball on the end, and if the ball isn't seated in the hook in the latch then it won't open the hatch.
Here's a picture of the end of the cable that is NOT attached properly:
Below is a picture of the cable where the ball IS properly seated into the release lever in the latch:
If your key isn't working, check that the cable is properly seated in the latch lever - if not, it's easy to hook it into the lever.
Bob
Glad you got everything working.
It sounds like there wasn't anything the matter with your Fob all along.
If you've got a dead battery, but you have a good Fob but no key, all you've got to do is get power back on the car so the Fob will work.
If you have a dead battery and the Fob won't open a door and you don't have a key to open the hatch to manually release the door, you can jack up the right front of the car to get under there and attach a battery charger or jumper cables. Once you get the battery charged back up or the system powered back up with jumpers, you can open the door with your Fob.
You hook up the power by attaching the negative lead to any ground, and the positive lead to the lug on the starter that has the positive lead from the battery attached to it.
That way you just charge up the battery and open the door with your Fob.
A better way is to make sure you have a key and that it works to properly pull the cable to the latch release lever.
There really is an easy way to solve these problems!!!
Bob
Bob
Good info on getting to the power source from the bottom.
