Header install first time.
Old Aug 12, 2009 | 10:22 PM
Bkbulldog's Avatar
Bkbulldog
Default Header install first time.
Ok this will be my first time attemping to do a header swap. I plan on doing this on jack stands. What tools will I need, and anything that can make it easyier. What should I expect to run into attemping this? Do you think I should even attempt this is the real question? What is the hardness on a scale 1-10. Anyone in the odessa/midland tx area to help . Any advice would be great. Im getting texas speed headers.
Old Aug 12, 2009 | 10:43 PM
Buddy A's Avatar
Buddy A
I don't know anything about the Texas Speed headers, but the LG Pros were the easiest header system I've ever installed. Just need basic hand tools, ie wrenches, sockets, etc... You will need a torque wrench. I drilled a hole in the plate above the headers and ran the O2 wires above. I made the hole right above the O2 sensors. I'm in Texas, but just a little too far..LOL
Old Aug 12, 2009 | 10:56 PM
Bkbulldog's Avatar
Bkbulldog
Do you think I can do it? Im just scared to break somthing.
Old Aug 12, 2009 | 11:05 PM
glennhl's Avatar
glennhl
If you've done any work on cars, it's not hard. Do a search, there is a lot of good information and tips on how to do it. I agree with the first poster, it's the easiest header install I've ever done. My 2001 Camaro was by far the hardest I've ever done. You'll do fine.
Old Aug 12, 2009 | 11:10 PM
Bkbulldog's Avatar
Bkbulldog
I did the intake install, taking the shroud off was giving me trouble haha.
Old Aug 13, 2009 | 07:27 AM
havoc77's Avatar
havoc77
I am by all means no pro.. but I just installed some 1 7/8 kooks on my 09 vette in about 2 1/2 hours and was really taking my time. I did have my friend with me to help hold things.
If you have ever changed your plugs, you should have no problem doing your header install
Old Aug 13, 2009 | 08:37 AM
Bkbulldog's Avatar
Bkbulldog
you do it with jack stands?
Old Aug 13, 2009 | 11:30 AM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Just remeber safety first and take your time, should be fun!
Old Aug 13, 2009 | 05:33 PM
Bkbulldog's Avatar
Bkbulldog
Well just got off the phone with LG and looks like im going to have them install the street headers and tune for what I think is a good deal. Also what RWHP should I expect to be at with headers , vararam, and borla exhaust after the tune? Hope headers is worth the money ha.
Thanks LG
Old Aug 13, 2009 | 06:47 PM
Buddy A's Avatar
Buddy A
It is pretty easy but if LG is doing it them I'm sure you'll be happy. Let us know how it turns out.
Old Aug 14, 2009 | 12:14 AM
Finster07's Avatar
Finster07
Thanks LG
Yes, LG headers and a tune will be worth the money. You will enjoy them.
As far as rwhp on your LS-2, my best guess is 375. I have kooks headers and a ported FAST and TB, and I am 400rwhp/400rwtq.
Old Aug 14, 2009 | 12:53 AM
Nightstalker Medic's Avatar
Nightstalker Medic
The header install should be rather easy. I did my on jack stands, no problem. I removed the H-pipe first and then unbolted the cats from the headers, then unbolted the headers and removed them from the bottom. I reused the OEM header gasket. I asked about this and was told that the header gasket was reusable, this saved me some money. Slid the headers in from underneath, just aligned the bolt holes and reinstalled the bolts, then torque to specs.
The only problem I ran into was the O2 sensors in the case iron heads. I could not get mine out. I have an 07 LS-2 motor. So I got out my saws all and cut the headers in half and removed the O2 sensors that way. Just make sure that you have your O2 extension cords, because the O2 sensors will not reach without them if you are using Long Tubes.
Are you installing a new X-pipe too?
Old Aug 14, 2009 | 07:38 AM
RyanC7's Avatar
RyanC7
I have a link to a header install on a C6 but it on my home computer. Someone might post it before I do but it is step by step.
Old Aug 14, 2009 | 01:28 PM
Bkbulldog's Avatar
Bkbulldog
They will tune the fans to come on earlyier right? It can get pretty hot here in texas. Also what improvments will I see at the track over stock tune?
To Header install first time.
