Has anyone modified the "quiet" side of thier NPP muffler to get a little more noise out of that side? Similar to what has been done to a stock non-NPP muffler??
I want to get a little more sound out of the quiet side...
I sure as heck wouldn't start drilling holes in my mufflers!...a bit hard to undo! You could probably replicate the idea I linked to with a pair of 25 cent fuel line clamps..not quite as elegant but same results.
Yeah, clamps would work. You really can see there anyways.
I did the drilling on my stock C6 exhaust prior to installing the ZR1 NPP mufflers. I was thinking of doing the same to the NPPs, but will try the clamps first.. :-)
I just wanted to see if anyone has modded the quiet side of their NPPs and read about their sound results
$25 isnt alot to get the sound you want w/o permanantly damaging the cans. If you can do it for a buck or so even better. Im going to order the SOD's clamps this week. The NPP's are quieter than stock mufflers. Open its FEROCIOUS! Need a little more testosterone when closed.
They are vacuum operated to get the "open" position and springloaded to be in the "closed" position when no vacuum is present. Should be fairly simple to wire them in the open position.
Actually it's the opposite. When there is no vacuum the butterflys are open, the spring actually keeps them open. Vacuum closes the valves.
Originally Posted by Bumblebee06
Related question: Since I don't have NPP on my car and I am installing z06 mufflers is there a cheap and easy way to simply keep the butterflies open?
Ideally this mod would be something I could undo pretty easy when I finally install the M2W kit.
Bumblebee06- The butterflies will be open if you don't have vacuum source hooked up. They will be constant "LOUD" with a mild drone..
I'm going to try the hose clamp first, if I can find one that small.
I looked at the exhaust exits. The butterfly side has four ~.75" holes (top, bottom, sides) at the rear chamber just inside of the perforated tips, rear of the butterfly valve. I was thinking if the clamp thing doesn't get the desired sound, then I will drill at the 6-oclock position of the "muffled" side, at the rear chamber of the muffler can, thrugh the inner pipe. This is similar to the mods done with non-NPP mufflers. I did this to my stock mufflers and got the sound that I wanted. I will then weld in a patch on the outer skin of the can to plug the hole there.
OK, I did the clamp mod today and I'm VERY happy with the sound. Just a tad louder than stock, with more rumble. No drone at at cruise speeds, a little when accelerating, but goes away quickly.
I purchase some 1/2" diameter hose clamps and clamped them to the rod that actuates the butterfly valves.
The clamp keeps the butterfly door open just a tad, enough to let some sound out..
Here's a pic inside the "loud" side. You can see some holes just inside of the tips that open up to the rear chamber in the can. I was going to drill the "quiet" side similar to this and then weld a patch plate to the hole in the can. I'm going to leave well enough alone because I'm happy with the sound achieved with this $1.50 mod
That one's easy, don't hook up a vacuum source to the butterfly accuator. They're spring loaded to be normally open and need vacuum to close, that's what the M2W unit controls. I ran mine with the butterflies open for a while before I put the M2W kit on and didn't like it. They drone pretty bad at lower RPMs. If you keep the car in 5th on the highway you'll be ok, but in 6th the drone gets a bit annoying
With the butterflies open just slightly, does it sound anything like an exhaust leak? What do you have forward of the NPP's? Cats/no cats, headers or stock manifolds? Stock cam?
For just an instant, before my NPP's are completely closed, mine does sound like it has a big exhaust leak. This "sounds" like a good idea. The cost numbers look VERY impressive. Guess I'll have to play with the clamp placement when time allows.
I have Z06 exhaust manifolds with a custom 3" x-pipe going to 2.5" over the axles to the ZR1 NPPs. Stock engine with exception of CAI. No exhaust leak sound, I get more of an exhaust leak sound with the butterflies fully open. It sounds like it does with the valves open, but not as deep, not as loud, and not annoying drone at low speeds...
The best part, the mod was dirt cheap, and reversable. I personally don't think I will move the clamp over any more than where it's placed now for fear of creating drone as this is my daily driver
anyone else tried this with headers and off road X pipe?
Can't say I'd want to here in California. I'm running headers with cats and with the Z06 mufflers open (loud) it's loud under throttle. Closed (quiet) isn't so bad unless you're pushing the go stick hard.
